S Type Transmission Problems
Old 03-06-2012 | 10:55 AM
JagV8's Avatar
Sounds like a biggish air leak which on that car is likely one of the (engine) hoses that fail so often at this age.
A zillion posts here about it and the fix.
Old 03-06-2012 | 12:50 PM
FritzTheJag's Avatar
Here is a great DIY video regarding maintenance on the Ford 5R55: Auto Repair: Fix Transmission Shift Problem Ford 5R55E Explorer more - 1AAuto.com - YouTube
Regards
Fritz
Amadauss (03-28-2012)
Old 03-06-2012 | 01:05 PM
JagV8's Avatar
Chances are it's not the autobox, though.
Old 03-27-2012 | 06:50 PM
David Lawson's Avatar
Screw it I drive the car hard with sport mode and manual shifts. Hell that's what I bought the car for is to drive some what hard and aggressive. However do not keep the car in sport mode in daily driving or you get this little well known GEAR BOX FAULT which means head on into the trans repair shop for a 2k tranny repair! Yep just a warning don't daily drive with sport mode or you to will be wiping tears away from a costly repair! Don't buy a Jag if you can't afford costly repairs! Several repairs I may add! I love them Jags! $$$$$
Old 03-27-2012 | 07:20 PM
JagV8's Avatar
Rubbish. You can drive with Sport on all the time if it's working right. If you can't then you have a fault. Judging by many posts, probably fixable at lowish cost, though not forced to be so.
Old 03-28-2012 | 08:05 PM
clubairth1's Avatar
Not true!!!
I leave my 2005 STR in sport 100% of the time.
Old 03-28-2012 | 10:33 PM
Amadauss's Avatar
Regards
Fritz
Just to confirm, what you are saying is that trans will be very similar to what I have in my Jag? Only issue re-filling the fluid and no dipstick. Also because of the various locations the fluid is located, hard to get an accurate measurement of what actually poured out of the trans. If you were to do this repair, where would you put the new fluid in? Thanks.
  #28
Old 03-29-2012 | 02:59 AM
JagV8's Avatar
Do not refill by measuring what came out. That is not how to do it. You don't know that it is correctly filled now.
If there's a problem with Sport then you know SOMETHING IS WRONG. It may not be the fill level, but there again it very well may be.
To anyone with problems, first find what's wrong.
There's a FAQ about working on the 5R55N (used in the 1999-2002 cars). But again - find what's wrong first. Many trans problems actually are Engine problems. (E.g. any kind of jerks can upset the autobox, and other issues do too.)
Amadauss (03-29-2012)
Old 05-27-2016 | 03:04 PM
Blake Bias's Avatar
my jaguar s type broke down
the transmission will not go into gear i use obd 2 scanner and pulled c1236
what should i do.
  #30
Old 05-27-2016 | 03:37 PM
JagV8's Avatar
Looks like 2 faults. C1236 looks like RH wheel speed (ABS) sensor. The trans... depends on your car details which you failed to put in.
  #31
Old 12-18-2019 | 12:43 AM
Reginald Crout's Avatar
Default Try changing the PCV, this fixed my problem, now I need to do that again
  • Originally Posted by cometgold
    I have a 2001 S-Type, 98000 miles, 4.0 . went on a short trip and on the way the display said transmission fault, shortly after that I lost drive. drive is now just like neutral. I moved the shifter to " 3 " and got home. Called the local Jag dealer and they told me they do not work on transmissions, they replace them. They want $7000.00 to replace it[:@]. Called a local AAmco transmission shop and they said about $2000.00[:@] . Does anyone have any idea what may be wrong with it? I dont want to spend alot of money if it is not necessary. I have not had it scanned for codes. Thanks for any help !!
  #32
Old 12-18-2019 | 04:36 AM
S-Type Owner's Avatar
Reginald, this thread is three and a half years old at its most recent post (prior to yours) and the OP has not been active since 2011. As a FYI, depending on the year/engine, some S-types are not equipped with a conventional PCV valve...
Thar said, welcome to the forum. You might want to go to the New Member's Area and post an intro; it is the expected thing to do and will help get you additional privileges on the site.
  #33
Old 06-19-2023 | 03:56 PM
lliytyt's Avatar
Originally Posted by oilman151
Hi Guys
We all know the 5r55n in our car is really crap. There must be another trans we can use.3.0 is a Ford engine. Theremust be be a better Ford trans we can use that bolts in or small mod to the mount.
Anyone know?
Regards
ford r
ranger manual 5speed converion it saved my wallet on the stype 3.0 used
BrentGardner
28
04-26-2024 04:08 AM
Woznaldo
01-31-2016 04:22 AM
martybmw
08-31-2015 09:41 AM
stanjag
08-30-2015 11:35 AM
NinoGrimace
08-26-2015 06:15 AM
Quick Reply: S Type Transmission Problems
