S Type tricky washer pump issue RESOLVED
Hello, having troubles with my S type, 3.0 Auto, MY 2000
Initial problem is the washers aren't working. Press in the washer switch on end of stalk, wipers sweep the screen but no fluid comes out the jets.
Pump doesn't make any noise, not a whir!
So far I have checked the following in this order...
Fluid level
Fuse no.2 in engine bay fuse box
Relay 13 in engine bay fuse box
Removed pump and put 12v to it, works fine
Tested the plug that goes to pump and no voltage when switch operated
Removed and checked the connections on wiper switch, all look good.
Next stage is going to stripping back wiring to see if there is a break, but access isn't great and is going to be a lot of work.
Am I missing something or is there a classic fault or something?
Thanks in advance
Fluid level
Thanks in advance
Received 6,326 Likes
http://www.jagrepair.com/images/Auto...01999.25en.pdf
Note there is a "Windshield washer pump" and a "Power wash pump". I have no idea about the latter. Does anybody know what the power wash pump is? Was it an optional headlamp washer or something like that?
Back to your windshield, you'll definitely want the windshield washer pump. You can do the bulk of your troubleshooting from relay #4 (not #13) at the front power distribution box.
First thing I'd suggest is swapping a known good relay into slot #4. It looks like relay #6 (horn) is the same. If your horn works correctly, then you know relay #6 is good. Plug good relay #6 into spot #4 and see if your washer now works. Plug suspect relay #4 into spot #6 and see if the horn still works.
If the washer pump still won't work, connect a jumper between the pump relay sockets 3 and 5. You can rig up a test jumper with two male spade terminals, or just use a paper clip. If the pump now runs, fuse #2, the pump, and all wiring between those points is good. The fault is with the signal that controls the relay.
To check the signal to control the relay, connect a test lamp or voltmeter between relay sockets 1 and 2. Turn the key to RUN and try your washer switch again. If the lamp illuminates (or meter shows 12ish volts) then you have a good signal to energize the relay. The power to energize the relay comes from the same fuse #2, previously tested above.
You've already mentioned the wipers sweep when the wash switch is pressed, so the switch and associated wiring is probably fine. There's no point in testing that yet.
There's a slim possibility the General Electronic Control Module has a problem, but I'd put that WAY down on the list of possibilities. I'm willing to bet large sums of your money on a problem with relay #4.
SSquared (08-30-2017)
Thanks for the long reply, and you are correct! Just logged on to update and saw your reply. Turns out the relay diagram i was going off only labeled the powerwash pump hence i concentrated on this. I then downloaded the correct wiring manual and found the windshield washer relay you talk of. Low and behold it wasnt fitted so tried one in and it worked. Will put the washer bottle back together soon and give it a proper trial. Not sure why it would have been Removed in the first place though. Thanks again for reply
Norri (01-29-2017)
Just curious, how long have you owned the car. I'm assuming (Danger! Danger!) the windshield washer has never worked for you. Don't see how it could with the relay missing.
A previous owner likely robbed that relay to replace one in a more critical circuit, and then forgot all about it.
Picked it up friday for the pricely sum of £200. No way i was driving it in winter without washers! Will do a project thread when i get time. Next on the list is rear window drops, so need to whip door card off and have a look whats going on with the regulator!
All that aside its a sound car with MOT until June!
i believe he was referring to the price of the relay not the price of the vehicle. I could be wrong but unless he just bought the car that friday, then definitely just the relay...
Welcome, NorCal. The forum member you are addressing has not posted in three plus years and the OP has not posted since 2017...
I see that this is your first post. It is customary (and expected) for new forum participants to post a brief intro in the New Members Area, which can be found here:
https://www.jaguarforums.com/forum/n...-intro-must-5/
JaguarVDP
12-01-2018 09:33 AM
