S-type V6 air in the Cooling System
Hey guys, I'm going to be helping a friend of mine do a coolant flush on his 2001 S-type V6 and I wanted to be as prepared as possible. What is the best way to purge all the air out of the system? I checked online before landing here and a few people where saying that the S-type has a self-purging system. If this isn't so, please explain the best way to complete this process.
iretribution (12-28-2013)
There are two places to bleed the cooling system on V6-engined cars, but care must be taken to not break the plastic hardware, especially on the upper radiator hose.
Air can be purged from the system on the upper radiator hose and at the coolant reservoir. The small hose next to the coolant reservoir with the plastic end cap is to bleed the heater core and remove any possible air pocket there.
If your friend has access to the JTIS manual, there is a description of the procedure for bleeding the cooling system on both V6 and V8 models, which can have different designs depending on MY.
Unfortunately we don't have access to the JTIS Manual. I've bleed air from the Cooling system before, but never on a Jaguar, and considering the vehicle isn't mine I wanted to be as careful as possible.
So in a nutshell, without the JTIS Manual, my best bet is to purge the remaining air from the upper radiator hose and coolant reservoir?
The JTIS workshop manual is a free download. Here is a link to the server containing the files for the S-Type:
http://www.mediafire.com/?3297awvo3atgw#jq3t61sbd3gd4
Yes, the bleed screw on the upper radiator hose can break and requires replacement of the hose as the bleed screw is not supplied separately as a service part.
On my 2000 3.0 I have a bleed valve to the upper left on the coolant filler cap.
Use this link and go to the end of my procedure.
Link http://www.jagrepair.com/DCCVSType.htm
I appreciate all the replies I've gotten! Tomorrow I will be going to my friends house to take a look at his Jag. We spoke on the phone earlier today and he filled me in a little more on what the situation is, before I write it out, if this reply should be posted as a separate entry let me know and I will do so.
The issue that he is having with the S-type is that the engine is overheating. He originally thought it was the low coolant/air in the system. Today he informed me that levels are where they should be but when the car has been running for a couple of minutes the temperature will start to rise, the only thing, according to him, that will cause the temperature to level out is to turn on the A/C. I will go over the JTIS manual (thank you for the link NBCat!) but I'm posting this to see if you guys might have some insight on similar occurrences with the S-type's V6.
edit: I will also be searching the forums for similar posts. Thank you all for helping me kill two stones with one bird.
I...The issue that he is having with the S-type is that the engine is overheating. He originally thought it was the low coolant/air in the system. Today he informed me that levels are where they should be but when the car has been running for a couple of minutes the temperature will start to rise, the only thing, according to him, that will cause the temperature to level out is to turn on the A/C. I will go over the JTIS manual (thank you for the link NBCat!) but I'm posting this to see if you guys might have some insight on similar occurrences with the S-type's V6.
Thank you for showing compassion for the birds...
FS[LowerAtlantic]: 2007 S-Type $.2 For Sale
captbob73
10-24-2015 05:49 PM
