S-Type windows and sunroof - all controls won't work
Hi guys
I am have a sudden issue with my 2003 s type. I had the car idling with all four windows down. ( sunroof closed) I opened the door to get out and move my other car. I got back in and none of the windows are functional. None of any door controls work to bring the windows up or down. the sunroof also will now not work. However, the global close and open works for everything. I havent tried anything yet. Any ideas?
Welcome to the forum xxphat,
I've moved your question from General Tech Help to S-Type forum. Members here with the same model will be able to help.
Id start by making sure your battery is charged and in good condition . Then try a hard reboot , here
https://www.jaguarforums.com/forum/s...d-reset-39172/
And worst case could be a broken wire/s to your drivers door module . In the door shut area .
I seem to recall global open/close also being non-functional when I had the broken wire, but here you go in case you need it:
https://www.jaguarforums.com/forum/s...allenge-98225/
Hi guys thanks for responding. I tried doing a hard reset today and still nothing. I then tried global and the windows and sunroof opened. I then tried global close and now only the sunroof closes. I tried wiggling the wires through the jam and still nothing. Ive checked window fuses and a few others for drivers side control and still nothing. I have the battery on a charger now i hope that does something. Where do i go from here.
I could be wrong, and it is just a thought, but I think this fault could be down to a faulty switch. I think if one of the window switched is effectively stuck down (on) then the system will time out and start doing strange things.
Try turning the rear window buttons off and check all the switches for positive operation.
Another culprit could be an after-market alarm/immobiliser system. But why anyone would fit one to an S-Type I do not know.
kr98664 (06-15-2018)
Update
Received 2,652 Likes
JimMLiny
11-06-2015 08:40 PM
cjdaniel316
05-03-2012 04:18 PM
