S Type won't start
S Type won't start
I am having a issue with my 2005 4.2 S Type. Any help would be greatly appreciated. Here goes.
Occasionally with no warning my car will crank but no start. When it does start it's immediate with no hesitation whatsoever. I have been having this problem for about 3,weeks now, and really don't want to get rid of it. I have just over 150,000 miles on it and believe that there is another 150,000 or more left in her. There is a code that is P0442, but that's it. Please help me save my 4.2...
Received 2,637 Likes
There are many items that can cause a no-start condition. Check for fuel supply, check for vacuum leak(s) indicated by DTC P0442 and check wiring loom to coils and injectors.
Does the anti-theft system function correctly?
Has any work been performed recently on the engine? Have the spark plugs been replaced?
Has the fuel filter been replaced?
You may also have a failing or weak battery, which can cause odd problems. With the ignition in the off position, there should be more than 12.2 volts across the battery terminals, if not, the battery must be replaced.
Raleigh (08-16-2016)
Thanks for responding. I have noticed that the doors haven't been locking properly for a while. So whenever I lock doors with remote, it unlocks. So I guess that the anti theft system is not funtioning properly.The spark plugs nor the coils have been replaced. I will check for vacuum leaks. I'm so grateful for your insight!
Raleigh (08-17-2016)
See the attached link for a brief description on my wife's rear door actuator:
https://www.jaguarforums.com/forum/s...ics-faq-65657/
The faulty actuator should not have anything to do with vehicle having a no start situation.
hisport
04-06-2016 10:23 AM
FS[NorthWest]: 2005 X-Type Sport Auto 42k miles $7000 Bay Area, California
Diavolo
03-25-2016 01:27 AM
03-13-2007 12:07 PM
