S-Type wont start after small bump
I hit another car while in a car park speed 5mph have scratches to bumper and wing slight damage when I went to restart my car S-Type 2004 2.7d it wont turn over. I have message parkbrake fault gearbox fault and restricted performance. I pressed the inertia reset switch but still wont turn the engine only the dash light come on no idea why ive drove this car 4yrs with no problems this was two cars hitting each other at 5mph max any help welcome
It does sound like the inertia switch, but if sure it's not then the next thing might be any of the items in the safety interlock against engine start. There's a lengthy no start PDF somewhere on here.
It might even be a bolt is loose/out for the trans shifter cable (side of trans, access under car).
gr1 (11-07-2015)
gr1 (11-07-2015)
All the inertia switch does is cut power to the fuel pump upon impact. If the engine won't turn over you have a different problem.
Be aware that the impact might have moved your shifter cable. Take a look and make sure the P is lighted on the shifter. Also try moving the shifter to N before starting and see if anything changes.
Get under the car and check the 2 small bolts holding the cable to the transmission. They are known to loosen with regular driving and yours could have been on the edge before the impact.
gr1 (11-07-2015)
hi thanks for advise its a 2004 2.7 diesel sport.my insurance took the car to a approved repair garage. vauxhal. they cant get the car started said needs jaguar specialist.the battery is 2yr old in good condition never had a problem starting.regarding the gear leaver or shifter I cant get it out of park still showing gearbox fault restricted performance.i spoke with jaguar they said there is a module in the front bumper or the wiring loom could have been damaged so now waiting for insurance to do damage report but vauxhal cant sort it they want to pass the job on
s type wont start
Received 2,266 Likes
It's obviously not 'basic electronics' then. If the engine won't turn over and you can't move the shift lever out of park, follow tbird6's advice about the shift cable.
gr1 (11-08-2015)
gr1 (11-08-2015)
