S type wont turn over - Please help (Fixed)
Old 02-07-2012, 09:12 PM
macksjaguar's Avatar
HI Jag and all.. Yes they surely didnt take very could care of it.. The air filter looked ok from the top but once i pulled it out , it was packed pretty solid with dirt. i change all the filters and it runs beautifully , it performs like a West Point Soldier.. Thank you again, mack
  #62
Old 02-07-2012, 09:13 PM
HI BFGross and Thank you again.. It sure was a chore , but it was well worth it..
  #63
Old 02-07-2012, 09:16 PM
HI Joyce and I went out the day it was running to take it around the block and well.. I was missing for about an hour and a half. I just kept going and going . It felt like i was riding on a cloud
  #64
Old 02-07-2012, 10:12 PM
Received 2,632 Likes on 1,813 Posts
Congratulations once again on a job well done! Your experience will certainly prove helpful to others facing similar obstacles.
NBCat
  #65
Old 12-22-2019, 06:14 PM
DrJagerCola's Avatar
Maybe a fried pin would cause [ PATS 24 ] code in my case.
I'm responding to add the PATS 24 keyword because he calls it fault 2-4 and I had a hard time stumbling upon it and the manual ends at 23. This will become an issue again and for others.
  #66
Old 12-24-2019, 09:25 AM
JagV8's Avatar
Received 4,528 Likes on 3,938 Posts
I can't see how you can fry a PCM pin - you'd take a fuse (or more than one) out long before a pin.
  #67
Old 12-24-2019, 10:17 AM
I'm told each port has a few resistors and so if it's not the connecting harness and pin that burned out it would be a few resistors that are easy enough to swap or order and replace by a qualified shop or handy do it yourself person.
We went back through the positively charged side and it never shorted to ground without the resistance of the solenoid and so the relays and fuses were fine at 10A and the EMS and so can't imagine where else it would be if this is the root of the problem. It just doesn't make any sense to say it hopped over the first failsafe and blew some other random relay but it's possible.
If people say it's the ECM, it's probably the ECM. A wiring issue that goes straight to ground would blow a fuse before blowing the PCM/ECM. The only way to do what I did would be to try to charge the non switched side of the solenoid by probing it from the back of the harness and using a test light to the battery. Otherwise, the two harnesses between them would protect the PCM and this would be a nearly impossible scenario we're facing. On the bright side, if I'm right it would tell us a little about our systems.
  #68
Old 12-24-2019, 10:32 AM
JagV8's Avatar
You're told? Who is this non-genius?
I think I want to stop trying to help as clearly you would rather listen to people who do not even know these cars!
Regardless, I wish you the best of luck as if you follow enough blind alleys you may get lucky eventually.
  #69
Old 12-24-2019, 10:43 AM
"non-genius" . There we have it. You're so full of yourself that you feel threatened by the electrical wiring expert and others suggestions.
Aside from that, I'm going to keep this thread going where I posted my own PATS 24 issue. Thanks for the battery advise it was good. Bye.
  #70
Old 12-24-2019, 11:09 AM
Received 6,307 Likes on 5,495 Posts
So, it looks like we are done here.
S-Type Owner (12-24-2019)
asleach2889
11-25-2015 11:41 AM
neilandt
30
01-10-2015 01:36 PM
nicholas.antony
12-24-2013 11:31 AM
parforbob
05-06-2013 02:26 PM
david phenom
08-22-2011 08:16 PM
Quick Reply: S type wont turn over - Please help (Fixed)
