same problem with car (studdering) but no error code???
All Fixed now
hello,
i have a post in the forum regarding the P0305 cyl #5 misfire.
which only happens at idle when it warms up and at 1500-2000 rpm's.
I'v done these things to resolve the problem and it is still studdering.
yet no error code comes up now.
to update,
i replaced number 5 coil all the plugs (iridium)
and the #5 fuel injector.
replaced IMT o-rings even though the upper was not leaking.
i took out and checked the lower manifold for cracks and or leaks so i replaced the gaskets all 12.
went through the hoses and lines checked them for cracks and loose fitting(none found).
cleaned and checked the fuel injector o-rings (seals).
what else would you recommend???
any help appreciated.
Eman
hello,
to update,
Eman
BrentGardner
28
04-26-2024 03:08 AM
Isoruku
06-19-2020 12:54 PM
