Sat Nav
Possable disk failure ?
or maybe you need to reprogram your audio's country of Origen . Via IDS / SDD.
i have a japan spec too ,
It has some differences to the uk and us audio protocol .
were as the short cuts that I see work for most
x type , s type and xj Nav premium owners are locked ,- such as the three button security code bypass is locked .
also the short cut three button access to the country/frequinsy option is locked .
-also the hidden menu can be accessed but any changes revert back to program default on next power up .
So basicly locked as well .
I found were you can manually check the boxes for components and country in IDS then reflash the modules .
but this is all useless if you have no access to IDS and a VCM .
just a thought .
just a thought .
Deanescar (07-23-2018)
Jeff DeVere
10-13-2016 07:00 AM
