Satnav DVD
Old 07-08-2020, 05:31 PM
TWR_Jaguar's Avatar
Default Satnav DVD
Is anyone able to upload the 2012 Denso satnav files? Or have a second hand dvd they want to sell? I've bought an STR but the disc is missing. Old maps is better than the naff "No disc" message I'm currently getting. Thanks in advance
Old 07-09-2020, 07:48 AM
JagV8's Avatar
Received 4,559 Likes on 3,964 Posts
You're asking to break copyright, which the site explicitly says you should not do (and it's illegal).
Old 07-09-2020, 08:30 AM
jackra_1's Avatar
Received 1,756 Likes on 1,327 Posts
Even if you can upload the files you will find that you can not burn them to a DVD successfully any way.
Old 07-09-2020, 08:59 AM
TWR_Jaguar's Avatar
Oh, not particularly explicit. Didn't see it in the New members intro rules. Apologies. I guess everyone here pays for Topix access and doesn't use the Jtis software that's Stickied on this forum. Or the JDS / SDD diagnostic gear. I'll bump this thread in 62years when the copyright expires.
Old 07-09-2020, 09:30 AM
TWR_Jaguar's Avatar
Thanks for some valuable input. From what I've read, you are right, regular DVD's will not work because of the size of the files. You need a Dual Layer disc and DL capable burner. Alternatively, I'll try and keep an eye out at scrappies for an S-type with the Denso unit. I would lament spending £30 on out of date maps. My 3 year old Volvo already needs maps updating due to all the roadworks that's gone on round here. Fortunately, Volvo provide the genuine files online FOC. You just need a USB drive with 50GB!
Old 07-09-2020, 10:05 AM
jackra_1's Avatar
Just wow! Takes all sorts I guess.
Old 07-12-2020, 04:24 PM
Joedotcom's Avatar
hi
if you google it you can find a copy of the dvd online
and yes you can burn it yourself, you just need a dual layer dvd
cheers
Joe
Old 07-12-2020, 05:15 PM
jackra_1's Avatar
Originally Posted by Joedotcom
hi
cheers
Joe
Of course you need a dual layer DVD duh!!! However it still will not work as the Jag disks have special markings on them.
Old 07-13-2020, 06:49 AM
M-e-l-l-o-w's Avatar
See this e-bay listing:
https://www.ebay.co.uk/itm//153542269129
Mellow
Old 07-13-2020, 10:55 AM
User 42324's Avatar
It does work & Joe is correct. I made three backup discs of the 2012 version as all my Jags use them. I've run with the backups in place for years & have zero problems.
If you're talking about any special markings, I think you may be thinking of the actual DVD label (which the reader cannot see) & are there to distinguish genuine from counterfeit.
Old 07-13-2020, 11:20 AM
jackra_1's Avatar
Ok so what specifically did you use?
I went thru multiple attempts using different burners/copiers etc on several different DVD type disks and although the burns appeared to work my NAV reader would not recognise them.
Old 07-13-2020, 12:13 PM
User 42324's Avatar
I thought I recognised your name, as we've had this conversation before.
Start at #4 here:
https://www.jaguarforums.com/forum/s...ftware-232503/
Old 07-13-2020, 12:32 PM
jackra_1's Avatar
Ok the difference then is that you had access to a file on the UK forum whereas I tried creating my own.
Any pointer to that image file?
I should add I am creating a backup file not anything to sell!
I think I found them but they are no longer there.
Old 07-13-2020, 12:54 PM
User 42324's Avatar
Almost correct. I said that I created one using an image file, but also created one by copying a disc. So I verified two different methods & they worked.
The image file from an ex-forum member's dropbox has not been available for some time. It's use to you is limited as it's for UK & Western Europe.​​​​
Old 07-13-2020, 01:05 PM
User 42324's Avatar
If you're trying to copy a disc you have, then the disc copy command or create image file should both work. What OS are you running & which software are you using to read/burn the discs ? Is it a quality disc, as car players are fussier ? Is it a -r disc, not +r & it's not a RW disc either ?
Old 07-13-2020, 01:06 PM
User 42324's Avatar
Duplicate post.
Old 07-13-2020, 05:19 PM
Joedotcom's Avatar
I copied mine off a friends disc who had a original, I just used roxio software which copied it and never had any issues with it
if your nav dvd player in the boot is tired, the laser that is, as most are now as there getting old, some wont read copies, some only read genuine ones, as the lasers are old and need tweaking inside, they can be adjusted and you can also buy new laser off ebay, but there not cheap
Old 07-13-2020, 05:30 PM
jackra_1's Avatar
I wondered about that as my original sometimes cannot be read unless I clean it.
I have another satnav reader and when I have time will have another go at this. Too much going on at the moment.
I tried a number of different readers/burners that were recommended and two major dula layer DVD suppliers one was Verbatim forget the other.
You have given me a bit more hope on something I gave up on.
Old 07-13-2020, 06:23 PM
User 42324's Avatar
Tried putting your copied disc in a different Jag to see if it works ? XF's up to 2015 (I think) have the same system as yours. If it works in another car then your player is the problem.
Old 07-13-2020, 06:26 PM
jackra_1's Avatar
I do not know anybody else near me with a Jag.
Not that difficult to replace my sat nav unit.
Quick Reply: Satnav DVD
