SC coolant hose
SC coolant hose
I have searched but can not find any good pics of the coolant hose that runs under the SC on the STR. I want to either rerout it or come up with a fix (maybe ss hose?) for it before it becomes an issue while I have the car apart.
Since my time is limited to have the blower off I would like to have the parts on hand before we get started. Anyone have any pics of links that show the problem hose and its connections well?
There was a guy on here a while back (automotive engineer I think) who just went through fixing this was going post a lot of detailed pictures but he hasn't done it yet AFAIK. Originally I think he was going to see about getting a one piece silicone version made up. I was wondering if just re-using the step-up connector and two pieces of silicone heater hose with a slip over woven nylon abrasion cover would be the way to go. But I've not had this apart, thank god, so I may be missing something that's obvious to those who have.
I'm interested in seeing the failure point of all of them. TTwotees had a bulging burst in the bigger diameter short section of the hose.
Here was mine: https://www.jaguarforums.com/forum/s...sc-hose-65682/ My mechanic replaced the hose with a new one but the part in the pic, like the 2" long connector, was pulled off and an silicone hose section was pushed on...
Nope and that's exactly what I was looking for, something that showed it and the points of connection. I thinking tap the head and water neck with a NPT X AN fitting and just use SS braided hose.
Did you put an entirely new OEM hose in or did you replace the short piece or what exactly?
I see from your other thread that yours also failed in the same spot as TTwotees.
I'm confused by your post. Your mechanic replaced it with a new one but you also talk about just replacing the 2" section?
It was very cheap from the forum sponsor, Nalley...
Staatsof (03-26-2012)
2008, coolant, cooling, engine, hose, hoses, intercooler, jaguar, replace, silicon, silicone, str, supercahreger, supercharged, supercharger, type
