Scorecard for Handbrake, Cruise Control, and DSC Faults - Was it the Battery?
Old 08-27-2021, 07:42 AM
kr98664's Avatar
Received 2,048 Likes on 1,446 Posts
Go Team Battery!
Post #17 here:
"Only real problem was electronic hand brake which often did not work, just parked in gear. Problem disappeared when I replaced the battery in 2018. The battery was the original Jaguar one which I had never replaced. New one solved the problem."
https://www.jaguarforums.com/forum/s...1/#post2433280
  #42
Old 10-16-2021, 12:57 PM
kr98664's Avatar
Yet another battery! Goodness, I could cut glass with my nipples. See post #8 here:
https://www.jaguarforums.com/forum/s...2/#post2451587
With this one, note how the new battery didn't clear the faults immediately. I suspect the battery was not fully charged at time of sale (very common), and required a bit of driving to fully charge it. Just a hunch, but if stated with enough authority, it sounds reasonable.
  #43
Old 02-17-2023, 11:51 AM
kr98664's Avatar
Three more examples to report:
1) A clear-cut tired battery, 14 years old! See post #11:
https://www.jaguarforums.com/forum/s...2/#post2454109
2) Here the problem wasn't the battery itself, but a loose cable terminal not making good contact with the battery post. Note in this example, only a DSC fault was present:
https://www.jaguarforums.com/forum/s...-3-0-a-266293/
3) Here's a very interesting thread. See the resolution in post #11, which also mentions the typical problem (DSC, PARKBRAKE, and ABS fault messages) resolved 5 years earlier with a new battery. In this latest instance, the only initial symptom was the horn intermittently sounding with the car parked. As the 5-year-old replacement battery slipped into the grave, the same three fault messages returned. Note how the battery was confirmed to have a dead cell. Even though the starter speed had dropped off somewhat with the failing battery, the decline was gradual enough to not be obvious. I mention this as a reminder not to use starter cranking speed to determine battery condition:
https://www.jaguarforums.com/forum/s...-issue-267177/
S-Type Owner (02-17-2023)
  #44
Old 07-13-2023, 11:14 AM
kr98664's Avatar
Another interesting one, caused by wear on the key:
https://www.jaguarforums.com/forum/s...0/#post2659928
Well worth a read. Also see post #15 above for a similar fix.
  #45
Old 08-19-2023, 10:26 AM
kr98664's Avatar
Go Team Battery! This one simply needed a good charge. See post #7:
https://www.jaguarforums.com/forum/s...8/#post2669158
The following 2 users liked this post by kr98664:
Lykkan (04-20-2024), S-Type Owner (08-19-2023)
MisplacedPriorities
04-17-2023 03:13 PM
wydopnthrtl
06-05-2019 05:46 AM
Dr John
26
08-26-2018 10:04 AM
Gerry755
08-04-2016 09:50 PM
kr98664
20
06-06-2014 01:04 AM
Quick Reply: Scorecard for Handbrake, Cruise Control, and DSC Faults - Was it the Battery?
