SDD says CCF is corrupt and As-built file is missing
Running v 131.03 sdd and im getting these two statements shown in pic below.
any ideas why? Or how to fix?
I also seem to have no recommendations listing under the campaigns tab in SDD. I thought at one point in time when I first loaded the software that there were things listed under campaigns but I may have tried to reload the software and lost it I’m not sure but I don’t have anything listed there now ever.
Are you sure both software and the reader are both legit?
When you say running SDD are you at the vehicle identification stage immediately after reading the VIN?
When I am at that stage I get nothing like that.I am using same version as you.
lmao. I was reading the list of equipment on the attachments you posted and I was thinking Jeez, this guys car is identical to mine. And then I realized it was mine!
thanks man! that’s a pretty cool print out you got. what did you use to get that?
I was worried that I had a corrupt file ir something bc several times ive seen the wrong options saved and I will change them. But id see they changed back. Like tire size. It seems to want to thing inhave 17” tires. So I select 18”. But months later itll be 17” again
hi,
just used Jaguar ids/sdd, you put the vin in and click the info tab and its displays the info above
the ccf corrupt is normal and comes up on most cars, this data was saved when new and stored on jaguar ids.sdd
cheers
Joe
