sealing the cowl from water
Some owners have indeed laid down a bead of silicone in that area for water-sealing purposes. Most tend to report back that it fixes their water ingress problem. Just be aware that whenever you must remove the cowl, you'll have to scrape off all of the old silicone and lay down a new bead upon re-install. That could add considerable time and effort to the process....
I would try foam window insulation tape, found at ant Big Box home improvement store. I cannot remember the thickness needed between cowl and windscreen, may be 1/2" (13mm).
Oh if that doesn't work. There was a member (Jons buddy
) that swore rubber base board molding worked........No pics in thread though.
Jon89 (03-23-2016)
edankeven
03-23-2016 09:48 AM
FastCat85
03-22-2016 10:39 AM
FastCat85
03-22-2016 10:27 AM
jaguarVP96
03-21-2016 05:39 PM
