secondary air
Chances are it's described in detail on jag's TOPIx (Search will get you more about TOPIx).
I expect it's air added to the exhaust to reduce emissions (emissions laws get tighter and tighter and ever tighter) - but see TOPIx.
I don't think it will be in JTIS as I believe it was added after JTIS ceased.
Secondary air is a system to warm up the catalyzers fast, helping reduce emissions from a cold engine (the over-rich air/fuel mixture and it's unburned HC) as the catalyzers work best when hot. There are two systems, a cheaper one that works at idle only, and a more expensive one with two exhaust injection points, an upper one to speed up up catalyzer heating and a lower one to help clean-up. There is an air pump that can get dirty/clogged, and it may be driven by a belt that can snap. It's an old idea from the 1960s.
Leedsman.
Leedsman.
I wanted to check that the system is working properly. I thought since the pump is working, the valve is working and there is no blockage that my next step was to check for correct voltage??? I found the SAI MAP sensor on the wiring diagram but can not find its location. Do you think I'm going in the wrong direction? Any suggestions?
scooternva
20
09-27-2023 11:25 AM
mel
09-20-2015 04:56 PM
Guy-Pierre Boucher
09-16-2015 05:55 PM
Andrew Fanshawe
09-14-2015 07:40 PM
