Select Ed. Warranty cover Headlamps droop?
Old 08-16-2010, 11:08 AM
JagV8's Avatar
Received 4,531 Likes on 3,941 Posts
Not unique to the S-Type. Lots of complaints on bimmer forums too. Probably elsewhere also.
  #42
Old 08-17-2010, 06:39 AM
Staatsof's Avatar
So the lamps are all normal and now I can drive at night. I have as yet to do that in this car.
Bob S.
  #43
Old 08-20-2010, 04:20 PM
cacloss's Avatar
Originally Posted by joycesjag
Bob S. and others with warranty, you might want to check the rear tie rod bushings (see attachments) they have been known to wearout. Jon89s went bad somewhere in the 35,000 mile range on his '05 (his warranty covered them), and mine were worn when we purchased the vehicle at 42k. The bushings are visable without removing the rear tire.
Great tip! Mine look exactly like yours did... I will call and verify it's covered before making an appointment
Thanks, again!
  #44
Old 08-20-2010, 04:55 PM
cacloss's Avatar
Called my dealer. Tie Rod Bushings are Not covered by Select Edition Warranty, per my Service Advisor. I was told "no suspension parts are covered".
Called Jaguar, they thought they were only covered if broken due to another part failure, but said the Dealer would know better.
I asked for any documentation that shows what "is" covered. She said she had a document that she would email me that says what "is not" covered. I'll let you know what I receive...
  #45
Old 08-20-2010, 05:20 PM
Jayt2's Avatar
Received 20,935 Likes on 8,420 Posts
Originally Posted by jagv8
Someone else had a bad gas gauge not very long ago and I think it was all fixed under warranty so has to be worth a search
(There are 2 level sensors and one or both can go bad.)
The racks seem pretty good.
One of them was me. Happened in Dec. 2008 and fixed under original factory warranty. Gauge was flopping between ~roughly 3/4 and 3/8 full. It does erroneously affect the mpg and other related mileage numbers on the computer.
Without warranty, it would have been ~$900 + -.
I'll have to dig up the paperwork to list what was done.
  #46
Old 09-14-2010, 09:17 PM
05STR's Avatar
Just got my Jag back from the dealer with a new drivers side headlamp assem, replaced under Select Warrenty ...
Only problem i have now it the right side looks dull.. time for a cleaning.. going to try the Mothers headlight restoration for power ball.
Skeeter
09-17-2015 08:15 PM
VRB
09-15-2015 08:18 AM
SeanU
09-13-2015 02:45 PM
edtexas
09-05-2015 10:49 AM
XKR-NC
09-04-2015 08:23 AM
Quick Reply: Select Ed. Warranty cover Headlamps droop?
