Self Leveling headlight problem
I have a 2005 Jaguar Stype. I have self leveling headlights. the problem i seem to have is the following: when i turn the lights on the headlights go through the leveling process. when complete the beam seems to be too low, only projecting about 12 feet. despite acceleration, deceleration etc no adjustments seem to occur...is there a way to adjust this or what could be the problem...thanks for the help
Dealership.. They need to be reprogrammed, its a veryyy common problem with these cars. Try doing a search next time and you can save yourself a post. At least 3 dozen people have started this topic.. My cars actually doing this very thing as we speak, I'm just too lazy to take it in. Eric
Received 2,194 Likes
Actually theyre broken inside, if you grab the electrical connector for the high beams after you remove the radiator cover, if they flop around theyre broken inside, if theyre firm and dont move theyre ok then you can go to have them program or checkto height sensors on the suspension making sure 1 didnt come unhooked. See my thread on fixing stype headlights if yours are broken
https://www.jaguarforums.com/forum/s...ad.php?t=10745
NOTHING IF YOU HAVE THE RIGHT SIZE SCREWS, AND ABOUT 5 MINUTES
Wow thanks brutal!! lol I just realized that mine were wobbling around just like you said.. I guess now if I can figure out that DIY I'll be able to fix them myself.. On my other car when this happened I had to pull the bumper, yank the headlight, and heat the headlight assembly with a heat gun and peel it apart.. and I discovered that the adjuster had come off of its track, easy fix.. hopefully the Jag will be even easier.. Thanks, Eric
Eric, if yours are flopping they may be totally broke top and bottom, the screw trick will still work, but you use a much moger 1 to basically pin the inside to the back and hold it steady. or you can pull the light, put it in the over @250 for 10 minutes, this softens all the urethane so you can easily pull it apart are TRY to repair. Ive used structural epoxy on other assemblies like Xtype and XJ's it works great. for some reason I havent gotten good results on Stype, but thats ok the screw trick is cheap and fast and works great
So is there a small piece of plastic protruding that you have to chop off in order to get to the hole where you screw the screw into? because that's what it looks like I have to do on mine? I can see the white whole, but its covered by part of the clear lens material.. Thanks for the help, Eric
white STRs headlamps
Even though you have auto leveling the headlamps still have manual adjusters to set the center position. You can follow this procedure if you aren't going to take it to the dealer. it really should be set with the IDS. Turn ignition on, this will auto level the lamps whether they are on or not. Turn headlamps on and adjust with manual adjusters, 6mm hex for both up/down and left/right. Broken manual adjusters are common on the S-type so if the lamps dont seem to move when the adjusters are turned re-post and someone will tell you how to modify your existing lamps to correct the problem which beats buying new lamps.
Of course a problem with the leveling is a possibility but that normally defaults the headlamps full down.
I transfered my post from the general section to here.
Brutal had posted some pictures of the procedure a few days ago but I'm not sure they made it through the site changes. You actually drill through the clear plastic portion to install the screw. Maybe brutal will repost the pictures if they got lost.
here Joe I linked it earlier....
also witht he vbulletin, now you can click on the persons name to view public profile and go to find all threads or posts that person either started or posted if you know they did
Self level headlights-You are the man Brutal
10 minutes two holes drilled, two screws and its fixed...thanks for the advice and from paying $2000 plus from the jaguar dealer. I stopped in afterwards and showed them the fix. Said thanks for trying to screw me by replacing them and walked out....what satisfaction. they stood there with dumbest look on their face..
Guest
Posts: n/a
Very nice, sir. I've posted my pictures in the main thread. Was yours similar to mine or to the ones Brutal showed? I'd love to fix this problem. I wouldn't even know how to go about adjusting the level otherwise (with the 6mm hex mentioned earlier...where do you even go with that tool?)...
need an update on what your outcome was......
Please do let me know.....
thanks!
Drill a small hole at an angle to the protrusion (actually a clear tube), not into it. Then screw in a 1 1/2" narrow sheet metal or wood screw at an angle into the center of the vertical doo-hickey you see within the leveling lens. When dark, turn on lights and screw in or out the screw as a means to set the height of the lamp egual to that of the opposite side.
