Self-repair code clear?
Old 05-09-2012, 07:50 AM
Leonard_85's Avatar
Brilliant!
You just reminded - we noticed the windscreen never properly "kissed" against the bottom seal, creating a gap and I can say with certainty rainwater could easily drip and enter beneath the windscreen area....
Time for me to get the overalls on (now my permanent outfit).
Talk about using language only heard in the most dripping alley-ways!
Old 05-09-2012, 08:10 AM
JagV8's Avatar
Received 4,527 Likes on 3,937 Posts
Good place to start. It may be (roughly) above where the PCM is. You probably need to take it out and check the connectors etc. I reckon your PCM is a sort of triangular cross-section metal box which should have a clear sealant fully protecting it but take a really careful look. There are other modules & harnesses near it so be thorough.
BTW, drying will most likely NOT be enough as corrosion has probably set in
Old 05-25-2012, 03:05 AM
Leonard_85's Avatar
Jagv8,
Thanks for your comments.
I don't have the JTIS (where can I buy). However i've attached an image of the connector beneath centre of the windscreen towards rear of engine block which has been exposed to rain water.
Are you able to identify this component?
Regards,
Shawn Svacha
02-06-2022 04:53 PM
Bcrary3
09-12-2021 05:41 AM
ccfulton
09-20-2015 05:15 PM
dwgates
09-11-2015 09:33 AM
mrplow58
09-09-2015 11:27 AM
Quick Reply: Self-repair code clear?
