Serious suspension play in the front passenger wheel
Old 07-13-2012, 11:19 PM
qwiketz's Avatar
photos of the work in progress. I should also add, if you're not replacing your brake pads, this is super easy. The pads just add a step.
Now it's onto the stabalizer links. BTW, anyone know if there is any particullar procedure when tightening down the suspension components with bushings such as the stabalizer links? Also, I checked out the sway bar bushing and will replace those too at some point even though they look allright. They're not cracked or anything at least but at $35, why not...
Attached Thumbnails Serious suspension play in the front passenger wheel-photo-1.jpg   Serious suspension play in the front passenger wheel-photo-2.jpg   Serious suspension play in the front passenger wheel-photo-3.jpg   Serious suspension play in the front passenger wheel-photo-4.jpg
Old 07-13-2012, 11:24 PM
joycesjag's Avatar
Received 1,712 Likes on 1,213 Posts
Originally Posted by qwiketz
Man I can't believe they wanted $500 to fix that thing. It literally took me longer to find the correct sockets than fix it. It was 2 18mm bolts for the caliper and 4 15mm bolts for the hub itself...
I told you that you could have done this job in your bathrobe!
Congrats!!!!!
Old 07-14-2012, 12:31 PM
qwiketz's Avatar
On a different note changing the wheel bearing quieted down my front right suspension quite a bit. It is noticeable when I go over bumps that is not as loud as before. I think I will change the stabilizer links and then change the left front wheel bearing as well. I am unsure about the sway bar bushings as when I looked at them they looked okay, but it should not be hard to change them if I do want to change them...
bdboyle
09-04-2015 06:16 AM
arnoldmilk
09-03-2015 07:42 PM
Harry Dredge
09-03-2015 03:04 AM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
Quick Reply: Serious suspension play in the front passenger wheel
