serpentine belt replacement
hey guys was just having my tires balanced and rotated and was told I needed a new serpentine belt, the guy showed it to me and you can tell that it was bad. Just wanted to know if this was a part that would be better to get OEM or is a aftermarket fine? and if so which brand? And what do you guys think labor is on this? I was quoted 395 installed.....
I am not too familiar with the layout of the v6 vs the v8, but I know I can replace both my belts inside 45mins with no problem.
Harbor Freight makes this
Serpentine Belt Tool Kit
Which makes changing the belt pretty easy if you wanted to tackle it yourself.
Received 6,320 Likes
If you wanted to try to do it yourself:
Buy Dayco Poly Rib Poly-Rib® Belt 5061070 at Advance Auto Parts
I like Advance because if you use coupon code p20, you save 20% off your order.
Alleycat66 (04-30-2013)
Yes---it took me exactly 3 minutes to lay the new belt on the pulleys on my 4.2Lwith a copy of the the JTIS layout in front of me and my 3/8 in johnson bar in the tensioner.
Removing and replacing the air box and other plastic bits took me about 30mins
https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-15/67367d1388953776-serpentine-belt-replacement-renew-drive-belt.pdf
I bought the belt from Jag and did it myself while I was replacing my water pump and thermostat.
If you don't want to DIY, go with the Jag dealer for that price.
I don't know how long you've owned your car, but if you can, get more used to DIY, you'll save alot of money that way, and less frustration over spending alot of money for every little thing that goes wrong, or maintenance items like this. Hope the above link helps if you decide to do it yourself. ( thinking of that Peter Gabriel song, DIY...Should be the theme song for this site!)
RoyLittle0
05-25-2023 02:38 AM
KarimPA
09-12-2015 08:15 AM
KarimPA
09-03-2015 07:32 PM
