Setting the timing on a 4.0 s type
Received 3,915 Likes
Womenlover, the JTIS doesn't say anything about how to set the timing, but if it is like my Ford 5.4L motor, if you look on the timing chain, you will find 2 links that are different colors than the rest (mine had 2 dark links). If you look on the VVT gear and the crankshaft gear, you will find some sort of mark on them (in my case, the crankshaft gear had a dot on it and the VVT gear had a raised dash on it). You line up the darker links to these two spots and you should be good. As for the small chain that runs between the VVT and the exhaust camshaft, can't help you there. I would say to take your time disassembling and see if you can spot any sort of match marks and note what they look like.
Hopefully this gets you atleast close to what you need to.
FS[NorthWest]: 20" Kasuga Wheels Set of 4 w/ Pirelli P Zeros
Johncy2000
12-15-2015 08:02 PM
FS[MidWest]: Secondary Timing Chain Tensioners
Bcrary3
09-12-2015 08:43 AM
stanjag
08-30-2015 10:35 AM
swarm27
08-29-2015 07:37 AM
Terrance Williams
08-26-2015 11:50 AM
