Several questions from filter to heat
Has anyone had issues when changing the air filter? I replaced mine and it's almost half an inch too long. I end up having to trim some of the rubber around the edges to make it fit. Without doing that, the filter will kind of bow upwards if I try to squeeze it in. Today I used a Purolator, I don't recall which brand I used last time, probably the same.
My next question is in regards to the defogger. Within minutes after starting the car, the passenger side is completely clear, but the driver side never clears up. The vertical line down the center of the windshield is perfectly straight separating the clear passenger side from the driver side. My windshield was replaced awhile back, but as it was during the summer I'm not sure if they did something at the time to break or disconnect a wire or this happened later on before winter.
Next question might be a dumb one in regards to the heater. It only feels warm if the car is moving. When I'm idle or in very slow traffic it feels like just a fan is blowing. Could just be the nature of the car, but I don't recall it feeling like this when I first got it.
Last question. Any suggestions on how to open the ashtray? I don't smoke so I use mine to collect loose change. Well, apparently I had too much in there and some slid around so now I don't have clearance underneath to push the lid down enough to unlatch it. Suppose I could just do some aggressive corning while pressing the button repeatedly in hopes that the coins move out of the way...
DO NOT CUT the air filter foam!!!!
The air box MUST be removed to seat a new air filter properly. Throw your "new custom fitted" air filter in the rubbish and purchase another.
If you would like to modify your AIR BOX for the next air filter change see this link: https://www.jaguarforums.com/forum/s...ghlight=filter
I thought Phaelax meant the cabin filter....got enchanted by all the other HVAC-related stuff, I guess....but there are different versions of those, too....but I don't recall a 1/2" would've made a 2000 fit an 03+....lots longer/wider but thinner, as I recall.
Defog - either something blocking the defrost outlet on driver's side...or...since it is dual-zone, may have a flap not working...does lack of heat exist on both sides? or only driver's?
Received 2,263 Likes
Received 2,192 Likes
Ide say engine air filter since i see many indepedant shop stuff a too long, too narrow air filter in jags and call it a day. This lets dirt and sand get sucked in past the airfilter damaging the engines ring seal. I see this so much i think someone (purolater, fram or whomever) has the wrong air filter part number to fit the jaguar stype. Also i never fully remove the air box lid since its too hard to refit the 4 tabs properly which also leads to non filtered air. I just undo the latched end, lift, slide out the old and refit a new one and its always in place properly....
![](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/8298d1299077120-several-questions-filter-heat-dirty-throttle-body.jpg)
Brutal, us DIY'ers should just remove the air box, since we don't change like a thousand a year. In reality it just takes a few more minutes to pull the air box up to get to those pesky tabs and fit the cover properly.
Thank you for your input!
Agreed. My approach is more time consuming : I remove the whole box and R&R the filter on the bench. But I only do them once in awhile for personal use, also an opportunity to regressed the box and mop up around the PS pump.
If you would like to modify your AIR BOX for the next air filter change see this link: https://www.jaguarforums.com/forum/s...ad.php?t=40687
http://www.youtube.com/watch?v=BVdBhdLkn7Y
Its an '03 STR, it used to say it in my signature which is why I didn't mention it.
woh yea i didn't cut mine into the actual filter like that, just trimmed the foam enough to fit in the box, it's still a tight fit. The purolator is the only one I can find for my car, K&N is never in stock(and I"m not paying $50 anyway) and I had to drive to two stores before I found the last purolator for it.
I don't see why I'd have to remove the entire box to fit the filter in, I removed the hose and took the lid off and set it in without too much trouble.
So which brand filters are you guys using that fit? Anything other than purolator I'd have to order online.
Back to the windshield defroster/heater. Looking at this diagram: http://zimnox.com/jaguar/diagrams/20...-Fuse-Box1.jpg
R21 is present but R17 is missing, and I'm assuming it should be there. My thought is that both those relays are for the issue I mentioned?
