Shock bushes
What I wanted to know. And you're right, I can get em half the cost if I order front; I suspect there's a lot more demand for front suspension parts as there's a lot more choice online, while much less so for rear components. The result is that rear parts are far more expensive, likely due to lack of competition. I was able to get a pair of front upper control arms for 80 bucks, and yet rears, which are very similar, cost many times more.
Can the bushing be replaced without removing the shock from the car?
Steve
Did you also replace front lower ball joint? If so, just the ball joint or the whole spindle with ball joint already installed?
Do you have a part number or online link to purchase rear shock bushings (the ones that are attached at lower control arms). I just got told by the mechanic that rear shock bushes are not available for my 2000 s-type 3.0 and I had to but the entire shock ~$210 per side for the part and $300 per side to install????
Steve
Steve
2 Front Lower Shock Absorber Bushing for Jaguar s Type 99 12 XF 06 12 XK 06 12 | eBay
The shock has to come out and the bushes replaced with a hydraulic press. Problem is, what you save on parts they might ding you on labour to swap the bushings. Personally I would pull the strut myself as it isn't hard to do, and drop the shocks off at a shop with the new bushings, and just pay to have them replace the bushes.
the front and rear lower shock bushes are exactly the same. Jag tried selling me the bushes for the front, but said the rear ones could not be replaced and i would have to buy a whole new shocker.....took to my mechanic, he punched out the bushes and swapped them over for both front and rear, using the same bushes.....job done
Apparently the front and rears are the same. I bought these but haven't had a chance to install yet
If I can drop out the rear shocks myself as a DIY in my driveway I will just do the entire shock swap job myself. I'm moderately competent mechanically but have never compressed springs and don't have a spring compression tool. Anyone know if it's a fairly straight forward job or am I going to potentially kill myself trying to compress springs?
That's because they want to replace the shock, which is separate from the spring. They both come out as one unit, but you have to compress the spring to remove the shock. If you just replace the bushing you don't have to.
FWIW my shocks have 155k miles and still work fine; I don't know how many miles are on yours, but given how easy it is to drop struts and inexpensive to replace bushes, my advice is to just replace the bushes for now; you could get many years more life out of them.
If you really want to replace the whole strut, a lot of parts jobbers have tool loaner programs, and finding a spring compression tool should be easy. They are straightforward to use; just google it and you'll find videos and such showing how it works.
Chuck Schexnayder
33
10-24-2015 10:20 PM
