Shocker bush worn
Hello Cully
I have recently replaced all four of these bushes, i was told that the rear ones are available but the fronts are not meaning a complete strut assembly is required. I found them available on ebay for front and rear. cost was about $30 a piece.
Fitting was quite difficult, unless you have access to a mechanical or hydraulic press i would not even attempt this.
You will need to remove the shock and spring assembly to do this job although i have read people have managed it without doing so, my opinion is this is impossible.
Special tools no, but deffo a mechanical or hydraulic press will be needed, usually found in a machine shop who will do this for you.
Any decent mechanic/ machine shop would charge about $200 for this so be sure to shop about unless your doing it yourself.
hope this helps and good luck
