Which side is "Bank One"? '02 3.0L S-type
Received 3,887 Likes
I think I have sources the gaskets to replace when I take the intake off.
What is the IMT o-ring? I could not seem to find that one(s).
Thanks again.
BugDoc, the IMT O-Rings are part of the intake. If you look at the intake, on the back side, you will notice 2 black plastic caps (about 3.5" in diameter) on the intake. Those are valves that alter the length of your intake tubes, allowing for either better low end torque (lengthening the tubes) or for higher horsepower up in the RPMs (shortening the tubes). If these leak, they can give you intake leak codes. It can possibly cause cat codes too as they are seeing too much oxygen, making the computer think the cats are not doing what they need to.
THANK YOU Thermo for explaining that 1..... My lower side IMT was full of blow-by oil (normal on these 3.0's, says Brutal). The O-Ring was allowing the blow-by oil to leak through the seal and drip onto my passenger exhaust manifold. Our vehicle did not throw any codes to indicate such.
BugDoc, I have pictures posted on a few posts here if you cannot find them PM me and I will send you the links. BTW Brutal is (was) a tech here and has not graced us with his presence for sometime, UNFORTUNATELY for us. Reread the response to your post IMT O-Rings.
Any "best price" Jag mail-order partshouses?
Thanks again for your help.
Oh. Just reread. It is dripping onto not into your exhaust. Still that is not a good thing. May not be the reason for my code.
I will try to find replacement IMT O-rings before I dig in.
Thanks to Thermo and JoycesJag for helping me learn about the IMT o-rings. Are the a rubber o-ring or a metal seal? Seems the pic I saw somewhere made them look 'like' a head gasket type construction.
(JoycesJag. I saw your link to the pic in the other thread... this forum needs more such pictures. 1000 words you know!) Thanks for the help.
BugDoc, like was mentioned, the IMT O-rings are going to be rubber (very hard rubber). There is not metal ring inside or anything like that. You may notice that the ones you pull out are a different color than you are going to install. This is fine. Jaguar upgraded the o-rings after the cars were made with something a bit better. So, no need to worry there.
Thang Nguyen
10-12-2015 01:25 AM
KarimPA
09-12-2015 08:15 AM
