Slotted and drilled brake rotors
Recently, I replaced my solid rotors with slotted and drilled rotors. They disapate heat well and look cool. The issue is NOISE. They are noisey, and when you brake down from 60 or so, it sounds like you have a bad tire. After 1000 miles, enough. I replaced them yesterday with the Bosch Super Premium Quiet Cast rotors. I kept the same pads because they don't throw much dust. The results are about a 90% reduction in stopping noise. It is back to smooth as glass. Now, if someone wants these rotors, just pay shipping and I'll give them to you. The noise may not bother some, but I like quiet.
The new Bosch rotors are anodized so they don't rust and are very quiet. I do have a full set of bling (rotors) if someone wants them.
So...after taking a close look at the picture you posted, I noticed you have Nexen tires installed. How do you like them?
I also installed drilled and slotted rotors on my S-type a few years back. The shop I usually go to was able to get me a complete set with pads for less than the regular rotors and pads. So, I decided to go for it. Sure, it looked blingy...but honestly, I didn't see much of a performance difference. But, alot of girls gave compliments...hahaha
Mine weren't too noisy though surprisingly...maybe my noise tolerance is off...
salmanezkhanz (01-29-2017)
Cool. Will give Nexen a closer look then. Thanks!
Make/Size/Stock Number?
What make/size/stock number are they? Have used them before on BMW and Benz w/o problems. I think sometimes the pad shims are the culprits for noise, and they do vibrate more with drilled/slotted rotors. I live a pleasant drive from B'ham, and might consider a trip to come get them if I can use them and you still have them. Thanks!
Front is 11.75 or so and Rear is 11.25 or so.
About 1000 miles on them.
CarGuy (01-30-2017)
p.s. Used to live in Shelby Co. and work in B'ham. One of the best kept secrets in the country. A Great Place to live and work!
Hmmmm. I think I may know what your problem was with these rotors. Look-up a set of Brembo or Stop Tech rotors and you will see what I mean. Thanks!
I think the difference is in the quality/price. Similar Brembo and Stop Tech rotors are $75 - $100 apiece. From the noise you describe, yours were probably already warped before you even installed them, and this cannot be determined by the naked eye. If it was a rotor and pad kit, I would be leery of the pads too. Brakes are one (of many) areas that you get what you pay for, especially when it comes to automotive "high performance" parts and components. I learned this the hard way...
