smell from cabin heater
I thought I had the same problem but took it to the dealer and found that the PCV hose had worn through and the oil was dripping on the manifold. It was happening when I turned the heat on or when I came to a stop. They figured that the PCV oil separator was gone on it too so I had it replaced. They had to take the intakes off and the lower ones too.
Guest
Posts: n/a
polisak -
That's sounds terribly expensive on the labor side. I hope that's not the case in my situation.
Did you have oil spotting where you parked it? I don't notice any leaking fluids on my driveway plus the smell from my cabin heater is distinctly the aroma of burning rubber or plastic. Doesn't happen at 71 or below.
This is terrible news.
Please read this thread. https://www.jaguarforums.com/forum/s...ad.php?t=30535
I had oil leak that came down to manifold and burt the oil. The smell was pretty bad. I fixed it myself by replacing two IMT O-rings. It's been okay for while. I need to monitor the oil level to see any more leakage.
Oh, I have pictures after I cleaned IMT and manifold. My manifold was covered with burnt oil.
