Smoke Coming Out of Vents
So, based on your two posts, I would say the first thing to check is the IMT o-rings. The check and repair procedure can be found in the FAQ section... Ask if you need help finding it.
When I had my 05 I never did see any indications of oil seeping out of the IMT housing.... BUT.... Got a distinct burning smell once they started leaking. The basic cause of this is that the PCV and EGR systems recirculate crankcase vapor back through the intake. Oil condenses and pools in the intake around the IMT valve. The original o-ring design is poor and eventually will leak allowing oil to drip down on the manifold. That "smelly air" is then drawn into the cabin causing the smell.
This would be the first place I checked since it is extremely common on these cars. That said, If that is not it the next thing I would check for is a coolant leak somewhere.. While this problem does demonstrate some of the characteristics of a failed heater core, that is very uncommon in these cars.
rsa760041
23
09-25-2015 01:33 PM
