SOLVED! 2k S-Type Misfire Idle issue/gasket help
Guest
Posts: n/a
I just purchaced a 2000 s type with a 4.0 Engine. Love the car and could use a few tips.
1) When I let the car idle at normal operating temp,"in the middle of the temp guage" and in park, it idles good for a minute or two.
but when it is in drive after about 10-15 seconds it starts hesitating or misfiring. But it drives excellent full power at highway speeds. But when at a stop light or sign it wants to miss.
No check engine light on, carb cleaner around the back or around the intake will effect the idle. The valve cover gaskets are leaking.
I did replace all spark plugs with motorcraft o.e and replace the #7 coil. as well as the bank 2 post cat o2 sensor"because I had a cyl 7 misfire code and bank 2 catalyst inif. code."
So my question is
what is your thoughts on the misfire/rough idle
Does anyone have a how to on the valve cover gaskets
Does anyone have a how to on the intake gaskets and what else should be done at the same time. like the elbow. Thanks for any help.
Sc0ota
So my question is
Sc0ota
Can it show datastream at all? Fuel trims specifically?
Take off the air boot from the throttle body and see if it is filthy?
Also the cat ineffciency code normally would indicate cat failure.
How many miles you have on vehicle?
Can you measure temperature from each tail pipe? Would be better if you have
infrared thermometer and measure cat temp.
Guest
Posts: n/a
ORIGINAL: Dennis
I have experienced this problem with other cars, by the way you described it, it sounds like a MAF sensor problem..
Guest
Posts: n/a
X_Type_South_Africa
12-09-2015 05:37 PM
