Spark plugs coming out of the plug socket
Simple question: Has anyone ever heard of a spark plug working its way out of the holes. Compression shoved it upward and the coil bolt bracket broke off. The threads weren't damaged and the plug was ok too. I did have to get new coil. Could it be too much anti seize or the silicone I put on the end of the coil to be able to take it off later. Only thing I noticed is that the coil tip had carbon on it and so did the exposed plug, so it had been wandering around loose for a while. The threads were all good too. Possible causes: I didn't tighten the plug and it was only hand tight. That's all I know except how it turned itself around.
Fire away. BTW this wasn't on my Jag, but the only expertise I trust is here.
joycesjag (02-18-2024)
Received 2,662 Likes
Depending on the application, anti-seize or other lubricants should not be used on the spark plug threads as some are lubricated already from the manufacturer.
If the spark plug has worked its way loose, remove the spark plug completely and clean or chase the threads in the cylinder head to remove the carbon. Install a new spark plug and coil unit.
The following 3 users liked this post by NBCat:
https://www.powerbuilt.com/products/...ir-tool-640811
Not sure which size you'll need, so double check before purchase.
This type of thread chaser is slicker than snot in a Minnesota winter. The business end collapses to reach undamaged threads deeper in the hole. Then it expands and you back it out to repair any damaged threads. This ensures the repaired threads remain in alignment. Any shavings are pulled out, too.
With a conventional solid tap, it cuts as threaded into the hole. It's easy to get cross threaded and stuff up the whole thing. Plus, it pushes any debris into the cylinder, even if greased up to catch shavings.
I did use anti seize on the plug. It was in there about 110,000 miles. I will drive it a bit and them take it out and replace it with a new one. Thanks.
I highly recommend an expanding back-tap thread chaser, such as the Power built #640811:
Received 13,203 Likes
Hi David,
xalty may be right about your threads - it would be prudent to have a good look at them with an endoscope. You can buy a cheap USB endoscope (a.k.a. bore scope, inspection scope) on Amazon that will work with your smartphone.
As xalty hinted, if the threads are damaged, they can be repaired with a threaded insert. Helicoil is a popular brand. If you haven't installed an insert before, this is a job for a professional.
Most modern passenger car and truck spark plugs are plated and the use of anti-seize is no longer recommended. NGK calls it's treatment "trivalent plating."
Cheers,
Don
Cheers,
Don
The following 4 users liked this post by Don B:
davidladewig (02-20-2024),
Gas turbine (02-18-2024),
joycesjag (02-18-2024),
MountainMan (02-23-2024)
New plugs arrive today. Will use my inspection camera before I put it all back together and be sure the threads are good. I bought the tool to re-thread it, but may not need it. That will go in the tool chest.
Don B (02-20-2024)
Thank you.
Don B (02-20-2024)
For the first time ever in almost 50 years of wrenching, I managed to cross thread a spark plug and damaged the first couple of threads. This was on a cast iron head on the 351W in my pickup. Oh anyways, I finally took my Powerbuilt back-tap out of the wrapper. It cleaned up the threads like magic. I can recommend this tool without hesitation. Buy one now before you need it and save yourself some aggravation.
Cheers,
Don
A 'lil bump:
if it makes you feel better I didnt tight an oil filter enough for some reason I cant explain and it loosened. First time in 45 years! Happened just recently and ive overtightened each subsequent filter due to my recent paranoia. I still cant explain how I left it loose. I swear I always go one turn past contact.
once I tapped main bearing thread on a mopar with a metric tap. Because I matched the tap to the main cap bolts they gave me (and said went to that block BUT THEY WERE WRONG and they werent for the block). I still built it though. and it is still running. Im shocked but laughing
JX350
11-06-2018 09:53 AM
55chevy
03-15-2018 07:07 AM
