speed and performance issue in S type 3.0
hi all, am a new member here i was looking for jaguar problems and solutions on the web and just fount this great forum.
am facing a problem with my jaguar
when i use max power i cant reach more than 160 and the gear doesnt shift to 4th
it just stay at 3rd
same situation in S mood or J gate or D
i have uploaded the issue vidoe on youtube
this is the link
jaguar performance issue ! any advice? - YouTube
just need ur oppinions on what parts shall i check and to find out if it is a common problem with this model
jaguar dealer in Dubai is realy expencive so am trying to avoid this visit
thanks
it just stay at 3rd
this is the link
thanks
O.K. I'm really confused here... the J-Gate was in 3rd, so it will not shift into 4th. What's the issue here? Show me a vid of it doing this with the shifter in D.
Edit: Nevermind, the last few seconds show it... But it also showed that once you let off it up shifted... Can you post a vid of what the car does when you accelerate in D? But at this point I think you need to get the TCM re-flashed at the Jag Dealership.
Dubai_Jaguar (12-13-2011)
Received 2,263 Likes
You are missing some serious power.
Most cars with high mileage in the UAE have been hammered the hell out of it.
On top of that, maintenance has often been skipped or wrong parts fitted.
Yours might have been running low on oil, or have wrong sparks plugs fitted if they were ever changed at all.
Have it maintained first and make sure filters an plugs are changed as a start and try over again
as i saidd in normal driving its verry smoth and the transmition shifts normally, am facing this only when i use max power i feel like there is no enough power comming from the engine because the RPM doesnt reach to shifting point. previously the car used to reach 200 km/h in same duration for current 160 kmh.
am sure about re-flashing TCM at jag delership without identifying the problem. thats why am keeping this visit as my last choice.
thanks
basically the problem is my Jag doesnt go more than 160 km/h and doesnt shift to 4th if am accelerating by max power at the end of the video i shifted from 3rd to 4th from 4th to 5th from 5th to D but doesnt shift also
spark plugs was changed at the agence at 120000 km and the milage now is 175000km
oil and filters just replaced two moths ago wich is less then 5000 km
hmm yeah jag dealer is the worst in UAE. they needed 4 days to discover a leak in water pump
thanks for ur reply here i posted another one in D
![Confused](https://www.jaguarforums.com/forum/images/smilies/confused.gif)
For this problem, I don't see the point of putting it in any gear except D. If I have it right, it just doesn't go past 3rd no matter how you drive it - I guess you're "feeling" the gear changes or relying on the speed and RPM to work out which gear it's in.
It would seem not to be developing as much power as it used to do - again, if I've understood.
Causes for not developing enough power include:
1. problem with delivering enough fuel into the engine, so:
1a. fuel filter problem
1b. fuel pump problem
1c. fuel line (hose) problem
1d. injector(s) problem
1e. problem with the actual fuel (such as its quality)
2. lack of air into the engine (so, check filter, etc) or perceived lack (e.g. MAF problem)
3. lack of exhaust out of the engine (such as damaged cat)
4. problem with some sensor the PCM relies on (not too likely, but such as IAT, ECT and so on are critical)
5. problem with ignition (coil/plug/wiring etc for them, but you also need a good battery and preferably alternator etc)
As you're using WOT you can ignore various things that can otherwise potentially be problems because they're not used at WOT (such as O2 sensors).
I've probably overlooked something.
Maybe the fuel filter? Quite easy & cheap to change.
Note my signature below for acronyms
