Spiral Cassette
Hi - I posted this question in "General Tech Help" but didn't get any responses. So, thought I'd post in the S-type-specific forum to see if anyone can help.
I have determined that the spiral cassette needs to be replaced in my 2004 S-Type. Before I order the part, I would like to hear from some of our resident technicians about what is involved in replacement. I am capable of nearly any mechanical work, and have a well-equipped home shop at my disposal.
However, I don't want to go "digging" for the component, damage anything, or waste time. So, before I tear in, I'd like to get a basic outline of where exactly the component resides, and what is required to effect replacement.
Thanks!
JD
Thanks!
JD
The problem stems from an illuminated airbag light that I have, and I found out from an earlier post that the code (19) indicates the "spiral cassette". No explaination was given for what or where that part is. Thus the reason for this post. I assumed that one of the Jaguar technicians on here, or an owner who has delt with this problem before, would be able to clarify.
Since the problem has to do with the airbag, and the word "spiral" is in the part description, it may be a module (?) that rotates (for the steering wheel airbag?) and mounts on the steering column (?). Or maybe something entirely different.
Again, I don't want to order the part, and then start tearing down the car looking for a part that "looks like this". I figured a tech could help me cut to the chase.
Thanks,
JD
JD I just googled "jaguar spiral cassette" and low and behold motorcarsltd popped up. You should inquire with them. www.motorcarsltd.com They post here quite often. The techs here have seemed to go on a vacation together, maybe sipping afew Corona's in Mexico. They are DUELLY missed.
First would be get jtis (ebay about $10, may be listed as workshop manual) as it's likely detailed in there. I think you'd have to remove the steering wheel. But anything to do with airbags: first disconnect battery and wait at least 30mins for all charge to die away. You do NOT want an airbag going off. Very nasty, very expensive.
Since this problem seems to be somewhat related to ambient temperature, I'm going to pull the wheel and check/clean the connections first. If that takes care of it, then I'm good to go. I'll find out if I've been successfull this spring when the weather turns hot again.
JD
