Spoke with the Akebono Rep
I had an nice chat today with the Akebono rep in Michigan.
For you guys with 06-08 STR's. I don't think there are many on here.
Akebono does NOT make pads for our cars.
He said production numbers for the final three years were below 300 and the company could not justify the re-tooling required to produce the parts.
I have ordered some Centric brand and hope they are correct.
They are made to OEM specs and will cause dust and probably wear fast like factory pads. At least with my black rims the dust doesn't show like it did on the stock color.
The one good thing is they cost only $75.00 total for front and back.
Thanks for getting us the scoop. I was planning on Akebono's for my car when I needed replacement pads and now I'll just have keep tabs on what others go with, and their results.
It amazing to me to learn there were only 300 STR's produced for worldwide distribution in the final 3 years. Is that correct? I guess the plus side is that we own a very exclusive vehicle.
I have heard that total production for all STR's is less than 2000.
The UK site has some info on it.
Be aware that almost all parts places will show Akebono pads for 06-08 cars. They have not updated their catalogues.
If you get a picture of the pads and they show holes for pins they are incorrect. The Brembos use pins ours don't. Ours have hooked edges that sit in the caliper carrier.
This might need some more checking. If you do some digging you'll see that the 06-08 R calipers are used on other cars also. So there may be hope yet.
Spoke with her also...
About a month ago, I spoke with a pleasant female at Akebono.
I'd rather take a beating than install those miserable factory pads
that deposit enough dust to change the color of your wheels in a
few hundred miles. I have an 06, past the 52000 SN with the
Teeves brakes. "Sorry," said she, we make pads for the rears,
but not the fronts. The car is normally aspirated, and, I assume
the production numbers exceed that of the R.
I have spent more than a few hours trying to find ceramic pads
on the net. Lots of bogus info out there. It appears that the
folks in Aussie land make 'red stuff' ceramics for the car; we shall
see.
see.
Besides the terrible dusting, these pads are really hard on rotors. Both the front and rear rotors are worn beyond spec after just 2 sets of pads.
Based on the number of STRs sold, I can see why part suppliers are reluctant to tool up for the late STRs. Oh well, it's still a great car.
Time to clean the rims... I can hear the dust collecting while the car sits in the garage...
Have you looked here?
This website shoes different pads for 2005 (Brembo) versus 2006 (Teves) so they're not just the same pads listed for both years in error.
http://www.centricparts.com/
Might be work a look?
As I was searching over the last month or so to figure out which MY I wanted to buy I do remember seeing one parts vendor showing replacement calipers for the 2006-2008 cars. When I took that part number and used their "utilised by which other vehicles" lookup it showed later Jags like the XF. Also I think some Volvos etc.
If this wasn't yet another catalog error then perhaps there will eventually be more pads out there because there are a lot more than 300 cars as a potential sales market. This sort of catalog omission happens a lot with limited production cars because no one in the aftermarket bothers to figure this out. As was preiously mention, who cares about 300 cars?
Bob S.
Bob S.
Akebono cared about 300 cars.
It was the rep, that said this is why they don't make pads.
They work with VIN #s and I don't think he had reason to lie.
I think the production numbers follow the pattern of low production for all STR's.
I know the Brembo calipers are installed on many other brands so those pads would interchange with many cars and warrant tooling and production of brake parts.
FS[NorthEast]: 2008 XKR Portfolio Convertable
Knomad
09-22-2015 04:36 AM
