Spoke with Eurotek today
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
I'v been talking with a guy from Eurotek about some of my concerns with the chip..
I think FJT, Brutal, or JagTechOhio said that the problem with the ECU tune is that whenever you take the car in for service there is a possibility of them reflashing the ECU and reverting your programming back to stock.
So I asked the guy about it today and this is what he said:
"Hi Eric we cover you for 4 years if the dealer erases the program so no charge for you. All you need to do is show us paperwork from dealer. Also Jaguar tech's on your car mostly reflash for the gearbox due to customer complaints of rough shifting. Very rare they flash the ECU for the engine. your car is a 2003 there are no open recalls or emissions updates so you have nothing to worry about. The stage 1 package is a great bolt on we sell these directly through Jaguar dealers its that safe and effective. Let us know if you have any further questions. We look forward to serving you. Eurotek "
What do you techs think, are there any other concerns I should address before doing this?
Eric
Eric
Greetings Eric,
Just chiming in so you can tick me off the list. I have zero direct experience with any of the tuning mods you are contemplating. The only outfit I have read about who publicly shares information and has product to offer is Eurotoys. No affiliation or other disclosures to make, I am not a customer.
Received 2,190 Likes
while they are correct you dont have any issue with yours recall004 currently is 04^. If i have a drivabilty issue with a car, not only will i clear adaptation, and reflash the trans, but the engine as well. Just like with windows updates new reflashes and software is always coming out of jaguar to improve the product and address different issues. That being said, i would be talking to any customer i work with like that and as long as i know you tuned, i wouldnt do it. And remember the only person that knows youre modded...is the tech, so develope a good working relationship with a good tech and go from there. Many dont want to deal with mods cause they dont understand anything but stock, i used to run a business years ago dealing with twin turbod nissan, supra etc. And am still into the tuning aftermarket with my nissan truck. Jaguar doesnt know if your trans came out from a totally stk jag, or a tuned and modded 100+hp over stock car, only the tech, so again get to know one guy, take him/her out for a beer, tip well be fair and remember them at christmas
We were using aftermarket tuning for the ECM. I can't remember who it was from though. We were doing cars in '03 and '04 when the STR and XJR hit the streets. I can tell you this, the pulley alone with no other tuning would pull at least 4 car lengths on a stock car in the 1/4 mile and the ones that got exhaust and ECM were more like 10 car lengths. This is all seat of the pants on the highway testing running modded car against stock car, no track time.
very, very intresting topic for i'am also a little leary of the reflash or tuning of the stock ECM unit. I saw somewhere on e-bay that a company would tune your stock ECM and send you there pulley along with a new belt, K&N filter for $1000 (ouch !)
Realtech-what kind of pulley was it? Was it the larger or the smaller upper one? I am new here as you guys can see, but used to have a modded 99 XJR, and just came from a modded 00 Trans-am-love the Jag. I have looked at Eurotek and Eurotoys-seems Eurotoys has more to offer and lists items as Eurotek seems to hide thier numbers and mods.
To increase boost, 2 ways, small upper blower pulley, or larger crank pulley. The only issue is as you go smaller upper you reduce the belt contact surface area and are increasing boost. Both of which can lead to belt slippage. But all upper pulleys i see are only 1 size down. But just to let you know this if your the "i want even more boost so i want even smaller upper pulley" to go more you can go to larger blower like the eaton based units that magnuson builds, port yours like white str's. Also taking the intercoolers off the engines coolant system and giving it its standalone system, not much to do there but to adapt a reservoir into the coolant the mix. Stillen has a reservoir that would proobly work with 5/8" inlet and outlet that i used on my blown app for the frontier. But since the r's have their own pump, and raditator in the grill youde just take out the engines connection, plug and reroute, remember not only is cooler air gonna produce more hp, but safer since its wards off engine damaging detonation more.
Brutal thanks for the info. I plan on waiting to port the supercharger-it was a nightmare on my 99 to get off and back on... On my 99 XJR I was the first to get my blower ported by Magnum Powers (prob still the only one)-man that was a sweet blower with a custom smaller pulley. I also seperated the cooling system from the supercharger coolant circuit and added a 12 or 14" (cant remember what size) cooling fan to the intercooler as a pusher. I made the fan come on with the car. The temperatures went down alot on the cooling tanks and you def could feel alot more power especially after heat soak. I did have some issues with the belt slippage and the belt hitting the water pump since this was a custom upper pulley and the place never had thier hands on the car--all was done through mail and the phone. The car would pull like crazy, at the track with only 9lbs of boost she ran a 13.2 at 106, I did see as much as 15lbs of boost when the belt would hold. Glad to be on a Jag forum where you guys actually mod your cars..!!!!
My 2 cents on ECU tuning here.
ECU Tuning via the post sounds a bit dangerous to me. Only if the tune is done carefully, monitored on a Dyno, and only knowing that the car is in perfect conditions (so good working MAF, all 8 injectors flowing the same etc), one could copy this tune which should be mild to other cars. Of course the condition must be that your car is exactly the same, so no different pulley size etc. Pending on how sharp one has tuned the ECU ranging from low risk (less extra power) to high risk (more extra power), the risks become even higher when you change more on your car (i.e. boost pressure). This is another reason why I am not in favor of mail-order tunes, one has no idea what has been changed.
Probably this was also why Eurotek is selling this ECU tune as a package (so with different pulley setup), but you would need to ask them.
Getting more power out of these cars with an ECU tune is child play, they are set very rich, but this is probably not done by the factory to increase fuel consumption…
Don’t get me wrong, I am not against tuning your ECU, but it would be the last tuning step I would take, and only with a tuner that has the experience and is able to custom tune on his dyno, and knows where the risk areas are to avoid an early death of an engine, so do not go to lean and make sure your car is in top condition before you start any tuning.
Andre.
Andre.
Andre.
Andre.
well hopefully it encourages people to get more. Just cause its a Jaguar, doesnt meen it doesnt respond like any other car out there. You just have to know where to look. Ide like to see some writeups on upgrades and mods. Along with some before n after dynos and or 1/4mile runs.....to see what and how much improvement resulted
@Bruta,
“So remapping fuel and timing for the ecu alone will yield better economy and performance depending on who tuned the maps and how they set them up”
We agree more than disagree I think, also with the later posts.
I am not talking here about economics or throttle adjustments, only full power map adjustments, where the ECU mainly relies on MAF signal to adjust fuel delivery and the IAT2.
All depends on how far some goes in fueling/ignition. If you alter more to your car (not just a filter/exhuast), by which I mean more boost (= more heat), one could get closer to the unsafe boundaries. Only way of knowing is with a dyno tune, but if one plans changes with only small stuff like filters or an exhaust I do not see an issue with a tune done before. Another major factor to be included is how will one drive the car, could it be prolonged full power runs (i.e. German autobahn, track), or is it an occasional pull? I wish I had an easy answer, but better be safe than sorrow, and know what you do instead of guessing what a remote tuner has done to the maps.
Cooling is indeed very important as the heat soak is taking away lots of power (as the ecu adjusts timing amongst others to avoid pre-ignition), so better cooling is already of interest for a slightly modified car, but even more so for a higher boost application.
The coolant circuits are only connected, there is no flow between them, all I can imagine a small drip or so. I would be interested to see real temperature measurements comparing an open and closed system, as so far I am not convinced that a closed system gives that much benefit, so anyone has some data on this?
Andre.
Andre.
