Springs, linear or progressive?
progressive-small coil spacing on the ends, larger spacing in the middle. the more weight on them the stiffer they become. As weight goes up so does the spring rate.
The higher the spring rate the stiffer the coil.
Linear-equal spacing through out the coil. retention of the spring rate through the weight range. as weight goes up springe rate remains relatively the same.
SD96XJ6L
11-05-2015 10:47 AM
