Squeak at startup
Received 2,263 Likes
+1 on accessory belt.
As Mikey pointed out - ensure the tensioner is working properly - there is a notch in the assembly that should be within the 2 marks. Also, again, all pulleys should roll smoothly and no "wobble" - if either are evident - change the offending pulley out before installing a new belt.
If that doesn't turn anything up, better have a look at the crank pulley. The damper can de-laminate and eventually it will either start tossing the belt or shredding it. On the +side, you have probably 3-6 mo between onset of tweeting and belt problems. There is a test involving putting a couple of marks on the pulley and damper but i don't recall the particulars. Search "damper" and that should pop it up. I know there is a good discission of it somewhere in the X300 section, but think it has also been covered here in S-Types. FWIW, I've experienced the failure in both the 7.3L Exc and a 3.0L S-Type.
Chuck Schexnayder
33
10-24-2015 10:20 PM
