sRS: flash 19, hard code B2293
There are a few ways to check the circuit. I have an assortment of 2.2 Ohm resistors in the proper harness plug connectors that I substitute for a certain part of the circuit I am diagnosing. You can disconnect the driver's airbag assy and the connector on the lower column. You then use a meter to test the cancellation module continuity. DO NOT TEST WITH AIRBAG IN THE CIRCUIT!!!
You run the risk of deploying the airbag.
The best way is to use a diagnostic scanner that can access the SRS module (B Codes) and use the DATALOGGER to read the Ohms VIA the Module. DO NOT READ THE AIRBAG DIRECT!!
bob gauff
bob gauff
