Stage 1 air intake tubes now available. Will fit STRs
#261
#264
Afternoon all (copied over from the XJR thread),
Just got back from the workshop working on the ideas for the carbon fibre air intake system. While there we knocked up one of the 'standard' type air intake tubes and have decided to offer these as a stage 1 kit (please forgive the blue silicon in the pictures if anyone wants one it will come with black silicon and stainless jubilee clips.
The major difference between ours and the normal ones is that you dont need to cut the oil breather hose or even replace it! this tube will accept the jaguar push on fitting, reducing the need to chop yours and allowing you to return to stock easily and without damage.
Also the end nearest the cast part of the inlet has been shaped to better resemble the oval shape providing better asthetics and a smoother transition from the round 3 inch T304 stainless pipe to the oval.
I can offer these for £105 complete with the 2x silicon joiners (in black), polished finish and 4x stainless jubilee clips plus fitting instructions. Installation should take no longer then 15-20 mins and the gains have all been proven. I will be doing dyno comparisons between stock, stage 1 and stage 2 (carbon full intake) as soon as the carbon one is done.
Delivery costs to the UK will be £5, if there is any interest from abroad will get the shipping costs for these as and when.
Some pictures.
Attachment 159238
The tubes will come polished as in the picture and fit very well. (It was raning on this one!)
Click this bar to view the full image.![](https://i50.photobucket.com/albums/f325/caldoofy/IMAG0142-1.jpg)
Turned stainless fitting TIG welded to the tube for jaguar oil breather hose.
Click this bar to view the full image.![](https://i50.photobucket.com/albums/f325/caldoofy/IMAG0151-1.jpg)
Standard oil breather fitted (sorry about the pic quality)
If anyone is interested let me know and we will go from there.
Cheers.
Some pictures.
Attachment 159238
![](https://www.jaguarforums.com/forum/images/statusicon/wol_error.gif)
Cheers.
#266
Welcome to the forum Jdbltrouble,
You don't have sufficient posts or length of membership to use forum PM or eMail. I've sent caldoofy your email address so he can make contact.
Hi call, I have a 2006 Street and I would like to lose the black thing and replace with a bit of bling. Could you give me a shout how to proceed as I just joined and still a bit unsure how things work on here. Cheers mate , Alan .
#269
Mods, might be an idea to remove his mobile number?
#270
#272
#273
#275
Price has increased since then now at $200 delivered to USA (postage and raw material increases) however still the only true 80mm pipe currently available and made in stainless steel Vs cheaper aluminium as well as the custom breather pipe barb that allows fitment of the standard breather. So still think this represents good value for money.
@Edat377 messaged you.
do you provide intake for range supercharged?
thank you very much
#276
You would need to post a picture of your engine bay as there are different variations of air box placement on the 4.2 RR supercharged for some reason.
For info the RR pipe is 90mm not 80mm and I can only do these ones in aluminium.
Delivered cost to you for the range rover version, assuming correct air box placement, is £150 to include the necessary silicone tubing to connect to your PCV valve.
Thanks.
Le
#277
#278
No problem, the manifolds will be priced at £1800 (only if good gains are seen on the rolling road) and will include 200 cell sport cats however don't know if they will fit a range rover due to totally different chassis arrangement.
#279
Hi i am very interested in this intake upgrade, i have an S type R on a 2003 plate, currently running 430 bhp, just changed the air filter to a KnN and had the upgraded pulley fitted and oil changed in the supercharger, how do i order one of these induction pipes please? Regards Dave in Kent UK
#280
Hello, I am new to the forums and have zero idea on how to PM. Would someone please enlighten me on this process as I would love to get an air intake. My email is colinmirey@gmail.com, thanks!
