On Start-up this morning- got a P0770 code
I drove the car fine all day yesterday including a couple of highway trips and a stop at a number of stores. Everything was working fine. This morning I start the car and get an immediate "gearbox failure". Drove a short distance and got a CEL and P0770. Car was in third, but no red flashing limp mode. Took it to a European repair shop in my same zip code and waiting until morning to see their diagnosis.
Has anyone had this code or one close to it before and what was the fix? I assume that replacing the solenoid makes the most sense and obviously getting a fluid change of a number of litters has to happen.
Any ideas or suggestions on this.
Tom in Plano/Dallas
05 S-type 3.0 123k
Tom in Plano/Dallas
05 S-type 3.0 123k
From the official jaguar workshop manual for code P0770 it states:
CLEAR ALL DTC's.
TEST the system for normal operation.
If DTC resets, install a new TCM and Main Control Valve Body.
(TMC is the Transmission Control Module)
However, random faults like this can be caused by low battery voltage, how old is your battery?
You can download and then look this up yourself in the official workshop manual.
Here is a link:
http://www.jagrepair.com/images/Auto...M-Workshop.pdf
Mellow
CLEAR ALL DTC's.
Here is a link:
Mellow
CLEAR ALL DTC's.
Here is a link:
Mellow
CLEAR ALL DTC's.
Here is a link:
Mellow
Spoke with the ZF service desk and they said- yes to check the battery, but being only a year old they had doubts. They indicated it is probably what it says it is and that is the solenoid and while there to replace all the solenoids as they can mechanically and electronically fail after many years.. Also indicted that replacing the bridge seal and the 4 small sleeve seals is practical to do on top of the unit. Said I would have other codes if other problems in the system.
But thanks for that and the battery suggestion is the second suggestion in that field.
TBB
S-Type Owner (01-21-2022)
Thanks Scott!
TBB
The shop verified through the electronics that the solenoid was not responding. I actually figure this since it just happened and no warning with any change in tranny performance. So I get, as ZF recommended as well as the shop, new solenoid kit for all, bridge seal, 4 tube seals and sleeve seal, plus fluid/filter and new bolts for the pan.
TBB
TBB
kr98664 (01-21-2022)
