Starting issues
It's a starting point at least.
IIRC, Another member did this a short while back on one of their relays that was causing a problem:
Check the blades where the relay plugs into for any sign of corrosion/rust/dust build up. Clean it as best you can.
Bit of electrical spray to give a little extra cleaning.
If, when you plug the relay back in, it slips in easily, take it back out, use a small screwdriver and CAREFULLY bend the tangs in the relay board in a little to make a tighter connection when plugging the relay back in.
For what they cost, replacing the relay for a new one wouldn't hurt either.
If indeed this is the problem at all.
dlowings (09-11-2017)
For giggles, try popping off the cover on the suspect relay. Look for any signs of arcing like on this one:
![](https://cimg4.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/572x546/img_1865_7a7d6601c28b0741e9b00e1094cb2e7a5e4f8a10.jpg)
The following 2 users liked this post by kr98664:
dlowings (09-12-2017),
Jumpin' Jag Flash (09-17-2017)
yep, I did try to start the car prior to messing with the relay, so I think the relay is a strong suspect. The car starts right up for now, so I'm going to drive it for a few days to see if it gives more issues. I may have the dealership order me one up just to have on standby . On another note, it started first try once again this morning. since I have fiddled with the relay, there have been no starting issues. so far so good .
Little bit of an update, After the past two days, the issue only happened once more and I immediately removed and reseated the relay and the car started right back up. Today I went to the Ford dealer and picked up a new one for 18 dollars. I put it in and the car started with no issue. I decided to take the old one apart and could see no arc'ing but the thing was EXTREMELY hot... I guess time will tell. As I was driving back from the Ford dealer, I was wondering if there could be something connected to the relay that is causing it to fail. I don't want to get ahead of myself but just trying to think of other things in case this is just a symptom of something else .
Did the new one get hot?
This thread talks about (hopefully) normal temperatures for relays in use:
https://www.jaguarforums.com/forum/s...-r-s-c-187819/
Yes, your fuel pump. There will come a time, probably sooner than later, when a new relay will not solve the problem. Your fuel pump is screaming, "I'm dying in here!"
#28
For peace of mind, you could test the amp draw of the fuel pump. The easiest way to do it would be at the relay socket.
