steering rack
Old 02-02-2023 | 01:36 AM
knares's Avatar
Default steering rack
my car had a few problems when i bought it but this is the first thing to go wrong while i have owned it
my wrack and pinion steering has started leaking from the rubber boots that cover the track rods
has any one replaced the seals or what ever
i cant find how to rebuild this in the manual i have
thanks
Old 02-02-2023 | 06:31 AM
S-Type Owner's Avatar
The lack of rebuild information suggests that the factory wants you to replace the unit with a new or remanufactured part. The gaiters and clamps are available as a separate part from Jaguar, but the internal seals are not. The actual rack from 2002.5 on is a ZF unit.
If you pull the rack and remove the gaiters, the seal numbers/designation "should" be available on the part itself. Hopefully the shaft is not scored and a seal replacement would suffice.
kr98664 (02-02-2023)
Old 02-02-2023 | 06:39 AM
knares's Avatar
thanks, what holds the seals in place, there must be a circlip or some thing
Old 02-02-2023 | 07:40 AM
Indeed there is:
Old 02-02-2023 | 11:49 AM
NBCat's Avatar
Replace the steering rack assembly and outer tie rod ends.
You can also have the steering rack assembly overhauled and shipped back to you. Perhaps someone in Australia can suggest a local source.
Old 02-03-2023 | 07:31 AM
knares's Avatar
thanks guys, he makes it look easy
Old 02-10-2023 | 06:30 PM
Catmobile's Avatar
Is the steering rack leaking a lot or just seeping and not losing much fluid? The rack on my car has been seeping for years and very rarely I have to add a tiny bit of fluid. If that's the case with yours, I wouldn't bother with it.
Old 02-10-2023 | 07:55 PM
knares's Avatar
thanks guys
it is leaking quiet a lot out of the boots near the track rod ends
still works ok
Old 02-11-2023 | 12:01 PM
Sportston's Avatar
I had a mate with an XJ who had the same problem. Every year before he took the car for its MOT he would drain the fluid from the rubber gaiters and re-clamp them.
Old 02-11-2023 | 10:26 PM
knares's Avatar
hahaha,yes, mine is leaking a lot more than that
i have just come in after pulling it to pieces, now i need to get the seals
gulley67
09-09-2022 02:03 PM
rik881
03-01-2017 06:17 PM
95Leaper
10-09-2016 08:13 PM
wintookit wizard
02-16-2012 02:19 PM
Rique
10-02-2009 04:19 PM
Quick Reply: steering rack
