Steering shake - 19" Summer wheels, Help / Advice Needed.
#41
Of course it would... I agree with the silicone spray and elbow grease approach if you really MUST detail an engine. Dare I even say a bit of armor all on a sponge on the plastics. I don't think in todays world of electronically controlled everything a garden hose is the best idea. See a pressure washer - unless it physically moves something with the pressure thus causing a problem that way, actually sprays less water than a garden hose...
I wonder your opinion what you guys think of those steam gun things that have become all the rage.
George
George
#42
I've heard that the steam cleaners are a big no no...But I don't have the references to back that up. I don't think I would do it to any car unless it was to strip certain parts during a rebuild. The pressure washer vs garden hose is an ongoing debate. I don't use a pressure washer vs the garden hose because despite less water it is under a lot more pressure..So much so, that it could force water past the seals on various connectors...Not good... Garden hose on the other hand, doesn't mess with the seals but will allow water to run into a poorly sealed area, hence why I will now stop using it on the Jag.....The van is another story....Gunk and the hose all the way!
#43
Oh, and DON'T USE Armour-All on any plastics at all. It is a silicone based treatment that contains petroleum distillates and will actually dry out plastics in the long run..Use this stuff instead... http://www.303products.com/
Or any other product that does not contain petroleum distillates.....I think Lexol makes a product as well, but I haven't used it...
#44
I've ripped out the power steering, heat + a/c, wipers etc... Sometimes you have to admire it's simplicity. (Although it does get 6 mpg trying to drive it as normally as you can on the street).
George
rusty37
04-05-2020 07:40 PM
