Stiegemeier Snake Bite Test - preliminaries
Old 07-21-2010, 08:35 AM
Riski's Avatar
I can smoke them down if I want, one tire that is....
So who is gonna do the LSD swap?
Almost bout a Lincoln LS rear and was gonna give it a try but missed the auction
Old 07-21-2010, 10:59 AM
vance580's Avatar
Still learning the STR. Is the Lincoln LS LSD and is the pumpkin the same part? If so I might have to hit up some salvage yards and look for one I'd be willing to try it.
Old 07-21-2010, 12:52 PM
ttwotees's Avatar
Spoke to Stiegemeier this morning. My kit is on the way back home. Hope to install
this coming Saturday. Will take and post photos. Stiege recommended running
NGK model BKR7E plugs, stock no. 6097 (Rock Auto - $1.76ea. in a pkg. of 10) gapped
at .032"-.035" for use with Snake Bite modification to your STR supercharger.
Old 07-21-2010, 12:55 PM
ttwotees's Avatar
Is the LSD an optional differential ? Where would you find one ?
Old 07-21-2010, 01:28 PM
ChrisSTR's Avatar
My concern with Steigemeier is just how much he knows about our cars. He's a Mustang guru without a doubt, but how many Jaguar Eaton's has he worked on. On what basis is he recommending these plugs?
Old 07-21-2010, 01:45 PM
Mafioso's Avatar
well Its a Trac-loc sold by Ford racing, I'll do it once I can confirm the spline count on our jags I have a 28 spline trac-lock for the 8.8 rear IRS. I was going to put that in my MArk VIII
Old 07-21-2010, 03:01 PM
flsupraguy's Avatar
Are you going to retain the stock supercharger pulley? If not, I wonder if it would be too much boost to run an aftermarket pulley combined with the Snakebite porting and internal regearing.
  #28
Old 07-21-2010, 05:33 PM
qwiketz's Avatar
they do the math and max out the step up ratio. You won't want to overspin it via a smaller pulely if it's already maxed out.
Old 07-21-2010, 07:52 PM
Jaxkr's Avatar
I have had many Jaguar superchargers upgraded by Bob over the years & never had a problem with one. In addition to superchargers he has also done porting on Jaguar cylinder heads for me. I am sending him a supergharger for a 2007 XKR next week to have the Snakebite done. I would highly recomend Bob to anyone, he has been doing Eaton blowers for years.
  #30
Old 07-21-2010, 08:07 PM
ttwotees's Avatar
He says he used to do maybe two Jaguars a month, but now he's doing several a week.
I hate to appear so dumb, but I'm going to ask two questions: How do you remove
the spark plug covers ? and Where is the supercharger coolant reservoir located ?
  #31
Old 07-21-2010, 09:08 PM
ttwotees's Avatar
Okay, I answered the reservoir question myself - It sets on the top of the radiator!
Mine's off, so I didn't see it, but when I looked at the blower coolant system in my
JTIS I could see it.
I still don't know how to remove the covers over the spark plugs ?
  #32
Old 07-21-2010, 09:43 PM
Received 2,192 Likes on 1,358 Posts
if you have a 4.0 they unbolt, so Im assuming your at least that smart so your must have a 4.2 which the covers just push down over posts. pull up evenly to remove
  #33
Old 07-21-2010, 10:04 PM
H20boy's Avatar
Received 1,151 Likes on 753 Posts
I pondered the coil covers for a few minutes initially also...then stuck a LARGE flat head screw driver under the cover from the top and gently pried inward (pushing the handle towards the block) and it pops off. Don't pull outward, you'll break the cover. There are two connection points, each about 1/3 the way into the cover.
  #34
Old 07-22-2010, 12:35 AM
avos's Avatar
Received 1,068 Likes on 761 Posts
@ttwotees
There seems to be some consensus that for high heat/high boost setups a copper plug is safer to use, as it seems they fire better in these conditions than Iridium’s. Another thought (not confirmed) I had was that the very small tip of the iridium’s could become a hotspot and thus a source of pre-ignition (again only in high heat combustion/high boost). As I am running mild boost with the KB, and haven't noticed any of the issues I just haven't experimented with this, so also continue with th e Iridums. However a copper plug may be a good idea for eaton high temp/boost conditions (just have to replace them more often).
Here is the recommendation from KB:
http://www.kennebell.net/techinfo/ge...SPARKPLUGS.pdf
  #35
Old 07-22-2010, 01:19 AM
JagV8's Avatar
Received 4,534 Likes on 3,943 Posts
Forgive what may be a silly question, but does adding more boost in effect change the compression ratio from the stock 9.1 nearer to (or past?) the 11.0 of the 4.2 NA engine?
If so, wouldn't the plugs used in the NA be fine?
  #36
Old 07-22-2010, 01:32 AM
avos's Avatar
It is the dynamic compression ratio that counts, as the actual compression depends on the time that the camshaft closes (which is usually after the piston is already in a compression cycle) and the amount of boost you apply.
As example here a link to a DCR calculator:
http://www.rbracing-rsr.com/comprAdvHD.htm
Next to that the heat is much higher with a faster spinning eaton. When I take the eaton website as example, the discharge air of the SC is about 300F above ambient, not sure how much the intercooler can cool this down, but it would still be much higher then the NA engine.
  #37
Old 07-22-2010, 11:27 AM
JagV8's Avatar
Thank you! I figured I must be asking a silly question but couldn't figure it all out
  #38
Old 04-11-2011, 04:54 AM
plums's Avatar
Received 2,183 Likes on 1,623 Posts
Did this ever pan out?
  #39
Old 04-11-2011, 07:04 AM
clubairth1's Avatar
Received 2,394 Likes on 1,888 Posts
No this will not work. If you are interested the Lincoln LS forums can answer the question in detail. The early 2000-2002 LS can have the center section swapped out for a LSD but when the Lincoln LS was upgraded in 2003-2006 the rear end was changed also. We "think" much like the S Type was. So the LS guys with a 2003-2006 either can swap the early rear end assembly in or use a Lincoln Mark VIII center section with custom mounts,drive shafts etc. No one has tried that with the S Type yet. The LS rear end was changed because of vibration and gear whine complaints.
Further problems-if changing the rear end ratio in the LS then no problem but the S Type will be put into limp home mode with a rear gear ratio change. No programmer yet for the S Type to over come this.
plums (04-11-2011)
  #40
Old 04-11-2011, 12:59 PM
plums's Avatar
Thanks for the detailed answer.
It's not quite terrible news for a X308 owner wandering into this section though
Time to hit the Lincoln fora.
workworkwork
10-01-2015 01:44 AM
leep123
09-30-2015 03:41 PM
pnwrs2000
09-30-2015 01:56 PM
ziondio
09-29-2015 01:58 PM
Quick Reply: Stiegemeier Snake Bite Test - preliminaries
