STR 4.2 S/C: Throttle "dead spot" at ~15-25% throttle position at 80-120kph speed
Very important it stays on , without it the second fuel pump will not strike up , hence the flat spot . I'm guessing at approximately 3800-4000rpm's.
mine was a little loose too and used a small zip tie around it as a hose clamp.
it's now tight and snug fitting .
po_snake (12-25-2017)
