STR Custom Wheels
Old 03-24-2011, 04:34 PM
JagV8's Avatar
Received 4,535 Likes on 3,944 Posts
I have seen it stated (somewhere!) that the offsets are 60
Old 03-25-2011, 12:11 PM
Mafioso's Avatar
The next time one of us has a front wheel off we need to measure the mounting pad, to edge of the barrel, that will give us offset.
IE: 8 inch wheel =203.2mm /2 to get center of the barrel. =101.6 is the center line of the wheel in mm so the pad needs the measured to edge of the barrel then subtract from the 101.6
Old 03-25-2011, 01:14 PM
kmrod22's Avatar
Originally Posted by qwiketz
Anyone ever mount xkr wheels on our s type r? The sizes are the same except 19".
There's a s type r with HRE's on ebay right now.
You'll get killed in tire cost.
Old 03-25-2011, 03:47 PM
Staatsof's Avatar
Give the Tirerack a call. I bet they know.
Old 03-26-2011, 01:59 PM
qwiketz's Avatar
True, but man, 19's look perfect. 20's look awkward and 18's look somewhat plain since they come stock. Just my opinion though.
Old 04-05-2011, 10:15 AM
American's Avatar
Just an update. I called these guys since they are semi local:
Wheel Repair By Adam‎
10952 Harry Hines Boulevard
Dallas, TX 75220-1316
(214) 357-5762
wheelrepairbyadam.com
Quoted me 165.00 each to repair the Zeus wheels. They will Tig the rashed areas to replace missing material then have a CNC machine that will cut them back to spec. Obviously for curb rash it's very minimal. They check to make sure they are true, etc. Then they will refinish the wheel back to the stock finish.
They told me it takes about 3 days, you can bring them the whole car and they will store it for you and do the turnkey job, bring them wheels/tires and they will remount/balance or just bring them the wheels, doesn't matter to them.
Guess I could put it on jacks for a few days and do brakes at the same time... and a fuel filter.
I'll probably wait until I have some miles on the Nexxens that are on there now so I won't feel so bad for chunking them in favor of some good tires...Conti, BFG or whatever I decide.
Old 08-07-2011, 11:39 AM
ffhillclimber's Avatar
OK so this morning I measured the backspacing on my standard STR wheels: Front: 6.75" Rear: 7.50". So I come up with offsets or ET of 57mm. This is greater than the 40mm I have seen. Did I miss something?
GT42R (02-26-2013)
  #28
Old 08-09-2011, 12:07 PM
fwilder's Avatar
I like the factory 19' BBS Barcelonas
Old 08-09-2011, 07:28 PM
Glockjag's Avatar
I agree
  #30
Old 08-09-2011, 11:12 PM
phaelax's Avatar
Originally Posted by American
Now.. there's the Stern wheels like Jaggyx runs on his X.
Victoria Wheel and Tire lists a ton of wheels for the R...IF they are truly correct in backspace/offset.
I like those wheels. Not sure if it's just the image or what, but it almost has a satin look to them.
  #31
Old 08-10-2011, 06:45 AM
Staatsof's Avatar
That's about the same as I was quoted including the dismount/mount & balance.
Mine had minor rash, no welding required so I touched them up myself.
(214) 357-5762
clubairth1
29
05-10-2024 12:57 PM
Dimitrigregorio
17
09-05-2019 03:47 AM
1LowCat
09-14-2015 07:51 PM
Andrew Fanshawe
09-14-2015 07:40 PM
edtexas
09-05-2015 10:49 AM
Quick Reply: STR Custom Wheels
