STR fuel pumps
STR fuel pumps
I have a non-starting car and would appreciate some guidance before I start replacing components. It's a 2004 facelift STR rhd and unmodified.
I had a few recent 'restricted performance' warnings which reset after restarting and no other intervention.
The car then died - as in it would crank but not fire.
I have established that I have a healthy spark, good battery and voltage at the pumps. I have changed the fuel filter (old one was not that old and not blocked).
I have a P2634 fault code which comes back on after clearing even though the car won't start. This refers to "fuel pump B control circuit high".
When I switch on the ignition there a definite short whirring sound from the n/s pump but nothing from the o/s.
Despite searching I cannot find any reference to which pump is A and which is B.
You can probably see where I'm going with this - things seem to point to the o/s pump being pump B and being the cause of the non-start situation.
Can anyone confirm which pump is which and offer any additional advice?
I don't want to pull both pumps unnecessarily.
Thanks.
Thanks.
i just read the RH pump pumps fuel to engine and the LH transfer jet pump transfers fuel from left to right . according to another thread,
in regular non R configuration .
this would lead me to believe in the R it would remain the same except the jet pump is replaced with a secondary fuel pump .
you can monitor your fuel pressure via obd2 using a cheep dongle and an appropriate phone app . or mechanically via the fuel rail on the RH side.
I would really like to know which pump is on circuit A and which is circuit B as there are separate fault codes for each circuit. That would imply there must be documentation somewhere that indicates which side is which.
correct thats what i said in post 2.
[/QUOTE] My understanding is that there are two pumps and that the arrangement is unique to the STR in the S-type model range, but shared with some 4.2 supercharged models of similar vintage such as the XJR[/QUOTE]
yes its the same non return fuel system as the 04-08 XJR.
[/QUOTE]Also that there is no primary and secondary pump but I stand to be corrected.[/QUOTE]
well there is .
well there is .
well there is .[/QUOTE]
Super.
But do you know which side is pump B and which side is pump A?
I assume not, or you would said so already, so does anyone else know?
It seems very odd to me that we have separate P codes referring to the two different pump circuits but there's no quick reference to which is which.
Super.
If it's not in the manual I'll work it out. Think I'll start with the pump that isn't making any noise. 50:50 so it won't take that long. Not surprised it's a rare code to be honest. I can't remember ever having a fuel pump failure in any car I've owned.
Received 6,354 Likes
Thank you Norri.
Do you know if the reference to left and right is viewed as standing behind the vehicle? So in a UK rhd drive car the rhs would be driver's side?
It would seem logical that pump 1 is pump A and pump 2 is pump B so it's a little frustrating the fault codes refers to A and B while the circuit diagram uses numbers.
You'll appreciate I want to avoid pulling both pumps unless absolutely necessary.
FWIW the B came from a Creader scanner. May help anyone else following a false trail like me although as you'll see by googling Jaguar P2634 it only brings up references to B.
I'm surprised it's the n/s pump as that's the one whirring when the ignition comes on but we'll see.
Unfortunately I have still have a non starting car. Been away for a while and now back on the case.
I'd appreciate some help getting to the root cause. Here's what I have/know:
Both pumps run (one is new). I have swapped motors and tested out of car.
I have a spark
Car will fire with a squirt of starter fluid
Have checked the two throttle body connections for water ingress - all dry
TB seems to be functioning - flap locked under power, normal whine with ignition on (TB not me)
Inertia switch in footwell checked
All fuses are good
New fuel filter
New quality battery and fully charged
Everything else on the car works as normal
Spins on starter normally
Not flooding and no petrol smell (have taken plugs out and checked)
P2634 cleared and no other codes other than the P1000 pending code present
I'm getting a fuel rail pressure reading of 321 kpa (approx 46 psi) from an electronic code reader with the ignition on
Pumps can be heard priming when ignition switched on
Nothing other than what's listed above has been messed about with since the car stopped running which does suggest a component failure
No revs registering on the counter when it turns over
So my amateur deduction is that something is stopping the fuel from being sent to the injectors or it is reaching the injectors but something is stopping them from working. FPS or something else? CPS?
Thoughts on the above appreciated. I keep looking at the mallet in the garage and am starting to lose patience.
I have a spark
All fuses are good
New fuel filter
check injector pulse width with a scanner or get a plug in noid light that flashes when the injector is supposed to fire....sounds like that is the only thing you are missing...a scanner is easier because you can do it yourself...not sure the manufacturer of the fuel delivery system is...you need to know that to get the correct noid light...usually you can get a set of lights that cover most all gasoline vehicles...you might even try cranking the engine with a helper and listen under the hood for the clicking sound of the injectors...a wooden dowel positioned near or on top of the injector works great for the click test...good luck
forgot to add...if no revs are registering..hook up to a scanner if at all possible and make sure it is reading that the crankshaft and/ or camshaft signal is being picked up by the ecm...it should be a yes or no data point...I believe it says ckp signal present...then a yes or no...i have a snap on solus pro and a very nice icarsoft unit that is for jaguar/landrover only....any scanner that reads the ckp sensor will work
I spoke too soon.
P2634 code is there again. "fuel pump B control circuit high"
In an attempt to isolate it I disconnected both pumps at their connectors and cleared the code. Connected the rhs first and no code. Disconnected and connected lhs and no code. Connected both and no code. Physical examination of all wiring not revealing any damage and all connections are tight and appear sound. Have also swapped the RECM in the boot to no effect.
I googled your code and found a wealth of info to read...there are a few good ones if you are interested and have not already done so....most of them point to wiring and/or module issues...even the the can bus that allows all of the modules to communicate with each other and the ecm can be the culprit....I am still learning about the returnless fuel system myself, but I am wondering if the pump in question is making too much pressure and the ecm is shutting the whole thing down for safety...just a thought
Depress the Schrader valve on the fuel rail after cycling the key off and on several times without cranking the engine.
Did you get a strong spray of fuel?
The STR runs off 1 fuel pump until 3000 rpm then both pumps are used to feed the engine. As was posted no jet pump on the STR.
I think you have to to be VERY close to finding the problem!
