STR fuel pumps
Well guys here is the answer although the precise sequence of events that led to this point may never be known.
Replacing the internal fuel pump - I used the Pierburg pump that is also used in the E39 M5 - seems to have got rid of the P2634 fuel pump circuit problem code.
I was then stuck with the non-starting issue and the usual suspects were all ok - I had running pumps, pressure at the fuel rail and a good spark. Therefore reasonable to conclude a fuelling issue. Why wasn't fuel getting to the plugs?
I had checked various fuses and relays but discovered one I hadn't looked at which is F17 in the engine compartment fusebox. It had blown! Simple replacement and the car started but with a misfire on injector 2.
You can just see the injector wiring under the supercharger and to my surprise I found the wire had made contact with the top of the engine and the insulation had melted resulting in a short.
It's a big job to remove the 'charger to get at the wire but I have been able to get some tape around the exposed wire and then enclose it using one of the those blue hinged snap fit connectors with the metal insert removed. The actual wire was undamaged by the shorting so I'm confident my fix will be adequate.
Thanks everyone for your suggestions.
Just hope anyone with a non-starting problem adds the F17 fuse to the checklist.
Norri (05-31-2018)
Jaguar S type fuel pump unit
