str lack of power
I cannot figure out what's wrong with my car for the life of me. I changed out the spark plugs fuel filter etc.. still the car won't run faster than 13.6 with a 2.0 60ft. Only trapping around 80mph in the 1/8. Car has Mina intake and pulley, x-pipe and magnaflow mufflers. Also the 3in intake pipe. Long term Fuel trims are out of wack also 10.5 and 12.4. I tried spraying carb cleaner everywhere to find the leak but there was never a change in idle. Couldn't find a leaky hose anywhere the PVC makes a hissing noise but I think that's normal. Anybody has any suggestions? Car has almost 100k miles
Well 13.6 is not bad depending on your altitude. What's the elevation of the track you run at?
Have you tried correcting the time back to sea level to see what it would run there? It's not exact but might give you an idea?
You don't have your car details but the early 2003-2004 STR's had a bad short shifting problem. During one of the early road test's the car only ran a 14.1!!
Are you getting to redline in all gears especially 1st and 2nd?
Mine had an air leak from the brake vacuum line to the master cylinder(something like that). This caused a bit I hesitation and loss if power only under load in the overdrive gears and no codes, but the jag scanner showed a lean code on one bank. The way the tech diagnose it was putting a smoker device in my intake tube and looked or leaks. They nailed I immediately so I would do the same and get it hooked up to a proper jag scanner.
clubairth1
29
05-10-2024 12:57 PM
Dimitrigregorio
17
09-05-2019 03:47 AM
jag79
09-21-2015 05:58 PM
