STR OWNERS- Gauging interest
#81
Mine-Its 3" unrestricted, no baffels, no silencing (sp) to create turbulance, softer bend to create more of a laminar airflow. Made from 6061 T6 Aircraft Alum, to dissapaite heat faster, and help prevent heatsoak.
Stock- about 2.75" oval pressed from 2 pieces so the inside isnt very smooth at the joint, 5 chamber/baffles to cancel the blower whine frequency which also creates turbulant air. plastic doesnt have the best thermoconductive properties, so it heats up quick and cools quick sure plastic can be better but the 6061 T6 alum acts more of a barrier against our foe heat.
Thats all I can think of at the moment.
Im still datalogging so I will have more finite details for you guys soon.
#82
#85
I'm not following your line of reasoning on this point.
So because the aluminum is a much better conductor of heat than the plastic it will shed the heat faster?
But it also will absorb the heat from the rest of the engine compartment more easily as well no? So at slow speeds like in congested traffic on a hot summer's day it's not going to be such a good idea . At least not in that configuration.
I thought you were going to eventually coat the inside with a ceramic coating ? Maybe ceramic on the outside isn't such a bad idea as well? Just asking ...
I'm not trying to critisize but I'm just confused about what the design theory is? Besides more HP of course! ;>)
A 3 mpg improvement? That one is maybe a premature figure? It's hard to believe Jaguar would have missed that sort of efficiency but of course the car is less refined sounding.
Bob S.
#86
Sitting in traffic is going to give you heatsoak no matter what you have. Unless you coat it with the same material that they put on the space shuttle. I can tell you that I am more interested in when I am on some curvy roads or at the track to have a performance gain. Who cares about performance in traffic?
#87
It's going to have a cummulative effect because that's basically what heat soak is. So it will take a while to cool it off again especially on hotdays. The idea is to prevent it in the first place.
I think (waiting for a clarification) he's planning on coating the inside with a ceramic coating and that the idea is that the heat from the rest of the engine compartment will be prevented from transfering from the tube to the air coming inside the tube and acting like a pre-heater? I would think that the outside of the tube will still be be getting heat soaked unless that's getting a ceramic coatin as well.
Anyway, I just want to hear what his operational theory is.
Bob S.
Bob S.
#88
#89
Exhaust headers are ceramic coated, generally..both sides.. to keep the hot gasses inside the tubes and away from heat sensitive items like starters and such.
I imagine the reverse would also hold true, to keep the hot under hood temps away from the cooler intake air.
Somebody correct me if I'm wrong, but that's my take.
#90
It has built in properties to help reflect radient heat instead of absorbing it. Which is what heat soak is.
[quote=Staatsof;261470]I thought you were going to eventually coat the inside with a ceramic coating ? Maybe ceramic on the outside isn't such a bad idea as well? Just asking ...[/qoute]
Yes that was in the orginal plans but the main factor is cost. Im still trying to source the best materials possible for this.
To date I have tried a ceramic coated mild steel, Stainless steel coated, and Alum 6061 T6.
[quote=Staatsof;261470]I'm not trying to critisize but I'm just confused about what the design theory is? Besides more HP of course! ;>) [/qoute]
Jaguar didnt miss it. Its all a balance Im tipping the scales. for the orginal intended target Im certain they would be bothered by the whine.
Enthusiasts want the whine. by deleting the resonating chambers creating a slightly larger radius for the air to turn it keeps velocity then taking a right hand turn, I have effectivly created less work for the blower to do. now it doesnt have to expend more energy having to suck through a coffee stirer, vs sucking through a McDonalds straw. thus giving you back more power.
I hope this helps.
If I am incorrect please do correct me, as I only have a somewhat limited knowledge of fluid dynamics. (Im a private sport pilot so in ground school we learned ALL about air and flow)
My Primary background is Electrical Engineering and I do find Fluid dynamics interesting and have a great concept of the principles.
#91
that would be correct!!
#92
#95
Yes Bob, the goal is to cool the charge temp and make the blower more efficient. The noises it makes is an added bonus
Phil_Deeznuutz, you wouldn't believe the change in sound it has made.
A nonsense comparison every dimwit with a Beemer,350z,370z,MB wanted to get a piece now that the elbow is on they hear me start to get on it and back off.
Not to mention seat of the pants is a totally different animal. It's come to my attention it's just not a good idea to drive with traction control off anymore
#96
![Icon Rant](https://www.jaguarforums.com/forum/images/smilies/icon_rant.gif)
#98
#100
