STR plastic supercharger cover
They can supply the latter, I'm fairly sure, as my local place thought they were what I wanted at one time. Are they maybe in http://www.drivehq.com/web/jfenley/P..._2000-2005.pdf
The local Pep Boys carries a wide assortment of various plastic and metal fasteners. Take one of your originals with you and you'll probably find something that will work for you. Advance Auto Parts and Autozone probably carry them as well. I'm assuming you have at least one of these chain retailers in New Zealand. If not, sorry to have wasted your time....
Sorry guys I tried NAPA and Lowes (sells different automotive fastners in the hardware department). NAPA would be your best bet you arent gonna find the exact ones but they should have some plastic rivets that will work. I found some that were pretty close but mine wouldnt let me try them out on my car without buying them.
Was gonna try a salvage yard but they were closed. I've seen the second picture part on various other cars. Just got to go and see if they will let you look around and see if you can find them. I believe that part is a Ford part cause they were on my Mercury that I used to have also.
I've done a little research on the clip in the second pic. I have found that it looks very very similar to the clips for my Mercury I used to have so checking out pics and Ford parts websites. If you have some salvage yards in New Zealand not sure if you have Crown Victorias or Grand Marquis but looking some engine bay pics of them it looks like they have the same clips on them. I found out its called a sight shield clip. Try a local Ford dealer and see if they have any in stock for a 03-04 Crown Vic or Grand Marquis and see if they will let you test fit it. I'll try and get up to my Ford dealership tomorrow and see if I can get them and if they fit I'll post up a part#.
![](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/5260d1285509936-str-plastic-supercharger-cover-wmimg_0306.jpg)
I've also just found this which is the actual part for the Jaguar. It shows it for the 3.0 but the clips will be the same across the board. If you cant find the salvage yard you can always just get new here.
http://www.gaudinjaguarparts.com/par...layCatalogid=0
The second picture is a standard Ford part. Jaguar Part #XR812941 $2.25 each. Ford part # W706519-S300 $3.12 each. Known as "Radiator Sight Shield Push Type Retainer". They are always torn up by somebody taking that shield off without knowing they unscrew and are not pried off!!
Sorry I don't have a part number for the SC cover.
clubairth1
29
05-10-2024 12:57 PM
Dimitrigregorio
17
09-05-2019 03:47 AM
